I have a two-piece Router Board Matel 5.8 belted dish measuring 32 db distance of 31 kilometers reference is -53/-54 … theQuality -51/-49 Our result is only 7-12 Mbit I want to solve the problem of quality
thank GOOD LISTENING
Please reply to my problem
Post screen shots of your config. Client and AP side.
Try to set adaptive-noise-immunity=ap-and-client-mode.
Did not work remained the same problem
On both sides (AP & client) set…
wireless protocol (wireless tab): any
hw retries (advanced tab): 15
enable nstreme (nstreme tab): YES/checked
enable polling (nstreme tab): YES/checked (AP side)
disable CSMA: YES/checked (AP side)
What is link distance and antenna specs?
dish 32 DBI
Cable Cat 6
Cable length 40 m
RB Metal 5SHPN 1300 w
colebert
Thank you for your interest
For start, go to both AP and CLE and check on the MCS panels UP TO MCS4 - NO more than that on BOTH panels.
Test it and post back.
Completed as requested by me
Became quality wobbling between 90/90 to 50/80 and so on
But it has become the best Provenance previously
Now, could you aling the antennas a bit better as you are?
Become better than before
Is it possible to become better???
Yes at 31km and IF your dishes are 32dBi, I WANT you to bring me 100% CCQ with MCS 4 ![]()
Settings are as follows
Data read the Advance 48
HT MCS 3 on both sides (AP&CLIENT)
CCQ 95/90
Are locked at 120Mbps Each?
Download arrived 30 MB
