Problem PCC Balance + PPPOE Server
Hello, I am having a problem that I didn’t have before with my PCC balance.
I used to have my clients with fixed private IP address each and the PCC worked excelente. I got traffic in my 4 WAN interfaces.
Yesterday I migrate all my clients connections to PPPoE, I created the PPPoE server, made the secrets and put a PPPoE client in each client’s CPE.
Since then the PCC balance only send traffic through one interface, the one with shorter distance.
This is my pcc:
1 chain=input action=mark-connection new-connection-mark=wlan1_conn passthrough=yes in-interface=wlan1/ether2/telmex
2 chain=input action=mark-connection new-connection-mark=wlan2_conn passthrough=yes in-interface=wlan2/ether3/fiber-noc
3 chain=input action=mark-connection new-connection-mark=wlan3_conn passthrough=yes in-interface=wlan3/ether4/FIBERCORP-DEDICADO
4 chain=input action=mark-connection new-connection-mark=wlan4_conn passthrough=yes in-interface=wlan4/ether5/equal
5 chain=output action=mark-routing new-routing-mark=to_wlan1 passthrough=yes connection-mark=wlan1_conn
6 chain=output action=mark-routing new-routing-mark=to_wlan2 passthrough=yes connection-mark=wlan2_conn
7 chain=output action=mark-routing new-routing-mark=to_wlan3 passthrough=yes connection-mark=wlan3_conn
8 chain=output action=mark-routing new-routing-mark=to_wlan4 passthrough=yes connection-mark=wlan4_conn
9 chain=prerouting action=accept dst-address=209.99.234.0/24 in-interface=Local/ether1
10 chain=prerouting action=accept dst-address=190.191.25.0/24 in-interface=Local/ether1
11 chain=prerouting action=accept dst-address=200.89.143.0/24 in-interface=Local/ether1
12 chain=prerouting action=accept dst-address=192.168.81.0/24 in-interface=Local/ether1
13 chain=prerouting action=mark-connection new-connection-mark=wlan1_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/0
14 chain=prerouting action=mark-connection new-connection-mark=wlan1_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/1
15 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/2
16 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/3
17 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/4
18 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/5
22 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/6
23 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/7
24 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/8
25 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/9
30 chain=prerouting action=mark-connection new-connection-mark=wlan4_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/10
31 chain=prerouting action=mark-connection new-connection-mark=wlan4_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/11
32 chain=prerouting action=mark-connection new-connection-mark=wlan4_conn passthrough=yes dst-address-type=!local in-interface=Local/ether1
per-connection-classifier=both-addresses:13/12
33 chain=prerouting action=mark-routing new-routing-mark=to_wlan1 passthrough=yes in-interface=Local/ether1 connection-mark=wlan1_conn
34 chain=prerouting action=mark-routing new-routing-mark=to_wlan2 passthrough=yes in-interface=Local/ether1 connection-mark=wlan2_conn
35 chain=prerouting action=mark-routing new-routing-mark=to_wlan3 passthrough=yes in-interface=Local/ether1 connection-mark=wlan3_conn
36 chain=prerouting action=mark-routing new-routing-mark=to_wlan4 passthrough=yes in-interface=Local/ether1 connection-mark=wlan4_conn
there are also some rules disable in the PCC that is why the number in the begining doesn’t mach
I think that the problem is the in-interface, before I changed to PPPoE all the connections were entering from “Local”, now, as the PPPoE creates a new tunnel interface for every user, the “Local” interface doesn’t match.
How can I fix this? because I can’t create one rule for every PPPoE client to make them match.
This must be a common issue, so please let me know how to fix it.
Thanks in advance.
Try a negated out-interface. If your WAN interface is called “WAN”, use “in-interface=!WAN”. If you have multiple interfaces not eligible for PCC make rules that just “accept” packets without passthrough, and then leave off the “out-interface” qualifier immediately. That way the ruled can grab the traffic coming from all the dynamic interfaces. If all of that doesn’t work (it should) or gets too complicated get a second router and chain them - one to terminate PPPoE, one further upstream to perform PCC.
I have 4 WAN connections, How can I use in-interface=!WAN in this case? Should I put “!WAN” in every place where now is “Local” ? (lines from 9 to 36 in the PCC balance)
I thought about the second router, leaving all the pcc balance in one and PPPoE server in other but as it is a common scenario I figured that there is a solution already.
Sorry, duh, of course the whole point of PCC is that you have more than one WAN interface. I hadn’t had coffee yet. Go for option number two I listed as it’s the only valid one.
Assuming they are called wlan1 - 4, add these:
/ip firewall mangle
add chain=prerouting in-interface=wlan1 action=accept
add chain=prerouting in-interface=wlan2 action=accept
add chain=prerouting in-interface=wlan3 action=accept
add chain=prerouting in-interface=wlan4 action=accept
Then move them so they are between the output chain and prerouting chain rules (starting at rule number 9), and remove the in-interface qualifier from all subsequent rules.
Do I also have to remove the “in-interface” indicator from the ACCEPT rules
Like this? :
9 ;;; AGREGADO FEWI
chain=prerouting action=accept in-interface=wlan1/ether2/telmex
10 chain=prerouting action=accept in-interface=wlan2/ether3/fiber-noc
11 chain=prerouting action=accept in-interface=wlan3/ether4/FIBERCORP-DEDICADO
12 chain=prerouting action=accept in-interface=wlan4/ether5/equal
13 ;;; FIN AGREGADO FEWI
14 chain=prerouting action=accept dst-address=190.191.25.0/24
15 chain=prerouting action=accept dst-address=200.89.143.0/24
16 chain=prerouting action=accept dst-address=192.168.81.0/24
17 chain=prerouting action=mark-connection new-connection-mark=wlan1_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
18 chain=prerouting action=mark-connection new-connection-mark=wlan1_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
19 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
20 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
21 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
22 chain=prerouting action=mark-connection new-connection-mark=wlan2_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
23 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
24 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
25 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
26 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local per-connection-classifier=both-addresses:15/>
27 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local
per-connection-classifier=both-addresses:15/10
28 chain=prerouting action=mark-connection new-connection-mark=wlan3_conn passthrough=yes dst-address-type=!local
per-connection-classifier=both-addresses:15/11
29 chain=prerouting action=mark-connection new-connection-mark=wlan4_conn passthrough=yes dst-address-type=!local
per-connection-classifier=both-addresses:15/12
per-connection-classifier=both-addresses:15/13
per-connection-classifier=both-addresses:15/14
32 chain=prerouting action=mark-routing new-routing-mark=to_wlan1 passthrough=yes connection-mark=wlan1_conn
33 chain=prerouting action=mark-routing new-routing-mark=to_wlan2 passthrough=yes connection-mark=wlan2_conn
34 chain=prerouting action=mark-routing new-routing-mark=to_wlan3 passthrough=yes connection-mark=wlan3_conn
35 chain=prerouting action=mark-routing new-routing-mark=to_wlan4 passthrough=yes connection-mark=wlan4_conn
It seems to be working.
How can I pay you? Are you a consultant?
That looks perfect, that is exactly what I meant. Everything above the four new rules stays the same, everything below them drops the in-interface qualifier, just as you’re showing in your latest post.
No need for payment. I do not consult. I’m glad it is working for you.
Thank you very much fewi, I already gave you + Karma,
Have a nice day.
Hello, I have a little problem now. It seems like the PCC load balance is redirecting all my traffic, even between CPEs.
I have a PPPoE session for admin, the address is 192.168.201.1, all the CPE get access by PPPoE clientes in 192.168.201.0/24.
Yesterday I could access all the CPE within the network just by connecting with my PPPoE session and entering de CPE address in the web. Now I can’t even ping the CPE address.
My guess is that the balance is taking all the traffic and forcing it to go throught Internet and not giving me LAN access.
Where should I put the IP 192.168.201.1 address as exception?
This is the firewall mangle today:
1 ;;; Empieza Balanceo de Cargas
9 ;;; AGREGADO FEWI
Thank you in advance, again.
Try this:
Make an address list that contains all your local IP space - all the IPs assigned to CPEs or elsewhere in your network. Below a simplistic approach that covers all private IPs.
/ip firewall address-list
add list=local-networks address=10.0.0.0/8
add list=local-networks address=172.16.0.0/12
add list=local-networks address=192.168.0.0/16
Then add the below rule, and move it just under the four rules you added for the WAN interfaces:
/ip firewall mangle
add chain=prerouting src-address-list=local-networks dst-address-list=local-networks action=accept
That will exempt all local network traffic from PCC.
It works great, but this will allow every client to communicate with each other, not only my admin IP.
Could I use scr-address with only my IP addres (192.168.201.1) to give access only my pc to every CPE on the network?
Yes, you could. You’d need two rules, one for the admin IP to the local networks, one for the local networks to the admin IP.
If you don’t want CPEs to talk to one another it would also be cleaner to drop the traffic in firewall filters than to rely on policy routing sending the traffic out the wrong interface.
I don’t want broadcast storms problems. Thats was what I was looking for to when I migrated my Fixed IP networks to PPPoE.
I have a wisp with over 200 clients and it was becoming a problem.
Broadcast storms wouldn’t propagate across PPPoE links.
Even if the CPE can talk to each other?
Even then. Broadcasts are for, well, broadcast networks. Point to point links aren’t broadcast networks.
HI
i am a beginner on mikrotik
i have to connect to WAN-s gateway (192.168.0.1 & 192.168.1.1) and three LAN-s(192.168.35.1 & 192.168.45.1 &192.168.55.1) i actually have configured it simple with both gateways at IP-> routes but i have some problems during work and the main problem is for videos on youtube for example they stuck and need a page refresh to be loaded.
i dont know if i can use the PCC technique , i don’t use pppoe at all.
thanks in advance
any advice ?!?
search and read and you’ll find out.
tamahome and fewi… you both have saved my world. I got my PCC working with the help of this post.
Thank you friends…
