Problem please help
Problem please help
I have a metal device when connected to electricity works only one light and then turns off, does not appear on the program WinBox never
What is the solution
Verify that you are getting enough voltage to the routerboard and if that is not the problem then you are going to have to replace it. You can try doing a reset, but it will very likely have to be replaced.
