hello
since i have upgraded my routeros to 4.3, all queue are not working, just if they were disabled.
what happen ?
from what version have you upgraded?
are those simple queues or queue tree?
do you have some limits on your queues, or they’re just for graphing? then, try to change at least something: for example, set queue type to ‘default’ instead of ‘default-small’
i upgraded from 3.20
i am using simple queues
i use queues for limit
i have changed type to “default” but still not working.
Thank you
what paltform is this? x86? If so then make sure xen package is not installed.
