The problem is not calculated or it is in use calculation without edited in the Online After QUOTA Outputs member of the Online but do not end so QUOTA User can log in again
You are not making any sense (again).
Please rephrase. And use shorter sentences when doing so.
Are not calculated QUOTA in PPP Is there a way to calculate quotas
What “quota”? Do you mean “queues”?
If you mean queues, the queue for each user should be added to a parent queue, so that the rate is divided between them. So add (manually) a queue, specify your total upload and download in it, and at the ppp profile, use that queue as “parent” queue.
no , I MEAN TX/RX LIMIT BYTES IN AND LIMIT BYTES OUT
Seems like a bug - another thing to contact support for.
If it’s a matter of a setting, I for one have no idea what it is.
So why there are fields to specify TX / RX, but no way to do that?
But you’re saying there are… Except that they don’t work. If they don’t work, it’s possibly a bug. If it’s a bug, you should report it to support.
