Hello all,
I’ve been working on this for a few days and searched everything I can think of… I had this RB450G working pretty well in my lab, but when it came time to deploy it, I had to add in PPPoE and tweak a few settings. It’s almost where it needs to be, but when I VPN in, I can only reach the management VLAN and I need to be able to reach the “Trusted” VLAN as well. I’m including a good chunk of my config just in case there’s anything else glaring I screwed up during all the changes. Thanks for taking a look!
Essentially I have the untagged (management), 10 (trusted), 20 (voip - future use), and 30 (guest mode) VLAN’s set up. Later I’ll block anyone on VLAN10 from seeing the default VLAN - right now eth5 is tagged for VLAN10 to go to a dumb switch; eth2-4 are plugged into VLAN-Aware equipment so they’re basically trunked. On the LAN side, I seem to be getting the desired results so far - it’s just remote via PPTP-VPN that I’m noticing a problem.
# apr/30/2012 15:21:38 by RouterOS 5.14
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=proxy-arp auto-mac=yes disabled=no forward-delay=15s l2mtu=1516 max-message-age=20s mtu=1500 name=\
bridge1trusted priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 mac-address=00:0C:42:FA:99:BE mtu=1500 name=ether1-gateway speed=\
100Mbps
set 1 arp=proxy-arp auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:BF \
master-port=none mtu=1500 name=ether2-master-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:C0 \
master-port=ether2-master-local mtu=1500 name=ether3-slave-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:C1 \
master-port=ether2-master-local mtu=1500 name=ether4-slave-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:C2 \
master-port=none mtu=1500 name=ether5-trusted speed=100Mbps
/interface pptp-server
add disabled=no name=pptp-in1 user=vpnuser
/interface vlan
add arp=proxy-arp disabled=no interface=ether2-master-local l2mtu=1516 mtu=1500 name=vlan10trusted use-service-tag=no vlan-id=10
add arp=enabled disabled=no interface=ether2-master-local l2mtu=1516 mtu=1500 name=vlan20voip use-service-tag=no vlan-id=20
add arp=enabled disabled=no interface=ether2-master-local l2mtu=1516 mtu=1500 name=vlan30guest use-service-tag=no vlan-id=30
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1 switch-all-ports=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
add name=pool0_management ranges=192.168.100.100-192.168.100.254
add name=pool1_trusted ranges=192.168.101.100-192.168.101.254
add name=pool2_voip ranges=192.168.102.100-192.168.102.254
add name=pool3_guest ranges=192.168.103.25-192.168.103.254
add address-pool=pool0_management authoritative=after-2sec-delay bootp-support=static disabled=no interface=ether2-master-local lease-time=3d name=\
default
add address-pool=pool1_trusted authoritative=after-2sec-delay bootp-support=static disabled=no interface=bridge1trusted lease-time=3d name=dhcp1
add address-pool=pool2_voip authoritative=after-2sec-delay bootp-support=static disabled=no interface=vlan20voip lease-time=1d name=dhcp2
add address-pool=pool3_guest authoritative=after-2sec-delay bootp-support=static disabled=no interface=vlan30guest lease-time=4h name=dhcp3
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=default use-encryption=default use-mpls=default use-vj-compression=default
add change-tcp-mss=default dns-server=192.168.100.1 local-address=192.168.100.1 name=profile1 only-one=default remote-address=pool0_management \
set 2 change-tcp-mss=yes name=default-encryption only-one=default use-compression=default use-encryption=yes use-mpls=default use-vj-compression=\
default
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 dial-on-demand=no disabled=no interface=ether1-gateway max-mru=1480 max-mtu=1480 \
mrru=disabled name=pppoe-out1 password=****** profile=default service-name="" use-peer-dns=yes user=********@sbcglobal.net
add bridge=bridge1trusted disabled=no edge=auto external-fdb=auto horizon=none interface=ether5-trusted path-cost=10 point-to-point=auto priority=\
0x80
add bridge=bridge1trusted disabled=no edge=auto external-fdb=auto horizon=none interface=vlan10trusted path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
set 4 vlan-header=leave-as-is vlan-mode=fallback
add disabled=yes ports=ether2-master-local,ether3-slave-local,ether4-slave-local switch=switch1 vlan-id=10
add disabled=yes ports=ether2-master-local,ether3-slave-local,ether4-slave-local switch=switch1 vlan-id=20
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=yes keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
add address=192.168.100.1/24 comment="Default Interface - for Management Traffic Only!" disabled=no interface=ether2-master-local network=\
192.168.100.0
add address=192.168.101.1/24 comment="Trusted Computer/Camera VLAN" disabled=no interface=vlan10trusted network=192.168.101.0
add address=192.168.102.1/24 comment="VOIP VLAN (Future Use)" disabled=no interface=vlan20voip network=192.168.102.0
add address=192.168.103.1/24 comment="Guest VLAN (isolated)" disabled=no interface=vlan30guest network=192.168.103.0
add address=99.155.144.54/32 disabled=no interface=ether1-gateway network=255.255.255.248
add address=99.155.144.48/32 disabled=no interface=ether1-gateway network=255.255.255.248
add address=99.155.144.49/32 disabled=no interface=ether1-gateway network=255.255.255.248
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.100.0/24 comment="default configuration" dhcp-option="" dns-server=192.168.100.1 gateway=192.168.100.1 ntp-server="" wins-server=\
add address=192.168.101.0/24 dhcp-option="" dns-server=192.168.101.1 gateway=192.168.101.1 ntp-server="" wins-server=""
add address=192.168.102.0/24 dhcp-option="" dns-server=192.168.102.1 gateway=192.168.102.1 ntp-server="" wins-server=""
add address=192.168.103.0/24 dhcp-option="" dns-server=192.168.103.1 gateway=192.168.103.1 ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=4096 servers=68.94.156.1,68.94.157.1
/ip dns static
add address=192.168.100.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no
add action=accept chain=input comment="default configuration" connection-state=related disabled=no
add action=accept chain=input disabled=no dst-port=1723 protocol=tcp
add action=drop chain=input comment="default configuration" disabled=no in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=pppoe-out1 to-addresses=0.0.0.0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip neighbor discovery
set ether1-gateway disabled=yes
set ether2-master-local disabled=no
set ether3-slave-local disabled=no
set ether4-slave-local disabled=no
set ether5-trusted disabled=no
set vlan10trusted disabled=yes
set vlan20voip disabled=yes
set vlan30guest disabled=yes
set bridge1trusted disabled=no
set pptp-in1 disabled=yes
set pppoe-out1 disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 \
max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/ppp secret
add caller-id="" disabled=no limit-bytes-in=0 limit-bytes-out=0 name=********** password=**************** profile=profile1 routes="" service=pptp
/queue interface
set ether1-gateway queue=only-hardware-queue
set ether2-master-local queue=only-hardware-queue
set ether3-slave-local queue=only-hardware-queue
set ether4-slave-local queue=only-hardware-queue
set ether5-trusted queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s multiplier=5
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 \
timeout=1m ttl=50
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" trap-target="" trap-version=1
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
