[problem] Router doesn't connect to ISP network
Hello!
I have a problem connecting my new MikroTik hAP ac2 to an ISP network.
My ISP provides static settings to use: IP address, subnet mask, gateway address and 2 DNS addresses. I have an optic cable coming to my house that is plugged into media converter that has a 100mbps RJ45 output. It is supposed to be connected to a home router. Also, my ISP supports DHCP connection, but this type of connection can’t be used to reach the Internet, you can only get to the ISP help and payment page. Nevertheless, DHCP is there and a router should receive DHCP settings. My ISP doesn’t have MAC binding (and I confirm this). When I connect my old TP-Link router or my laptop directly to the media converter I have no problems at all, everything works flawlessly. However MikroTik device is unable to route traffic outside of LAN. I can’t ping anything (even ISP gateway) apart from LAN hosts both from local devices and from the router itself (it says “timeout” or sometimes “host unreachable”). However it says that link is up and the led is blinking. I’ve tried using both “Quick Set” and “WebFig” setup with no success. DHCP mode just doesn’t get any settings (infinite “searching…”) and static setup doesn’t work as well. I can’t see any errors, it seems like it should be working, but it doesn’t. Cable test is “ok”, but to be sure I changed the cable. No success. Of course I have double checked all ISP settings and everything is right.
My temporary solution is this. I connected my old TP-Link router to the media converter, disabled it’s wi-fi and then connected MikroTik device to it. Both devices run DHCP server and have NAT enabled. TP-Link subnet is 192.168.1.0/24 and MikroTik is 192.168.88.0/24. In this scenario everything works perfectly, I have access to the internet from my MikroTik router and all the devices connected to it. MikroTik is the only device connected to the old router. My TP-Link configuration page / telnet (192.168.1.1) are accessible from MikroTik subnet as well.
So…
Desired setup (not working):
Fiber optic cable —> [ Media Converter ] — Cat. 5 Cable —> [ MikroTik router ] —> Clients
…and it’s “export compact” output:
add admin-mac=48:8F:5A:71:BC:97 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=russia4 disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=russia4 disabled=no distance=indoors frequency=auto frequency-mode=superchannel installation=indoor mode=\
    ap-bridge ssid=MikroTik tx-power=40 tx-power-mode=all-rates-fixed wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=*** wpa2-pre-shared-key=***
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=10.34.0.113/24 interface=ether1 network=10.34.0.0
/ip dhcp-client
set allow-remote-requests=yes servers=10.10.10.3,10.10.10.4
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=10.34.0.1
/system clock
set time-zone-name=Europe/Moscow
/tool mac-server
/tool mac-server mac-winbox
My current setup (working):
Fiber optic cable —> [ Medial Converter ] — Cat. 5 Cable —> [TP-Link router ] — Cat. 5 Cable —> [ MikroTik router ] —> Local hosts
/interface wireless
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dns static
add disabled=yes distance=1 gateway=10.34.0.1
/system clock
/tool mac-server
I tried to contact my ISP support with no luck. They just said that MikroTik routers are just too difficult to setup so they can’t help : )
Sorry for mistakes if there are any, English is my second language. Any help would be appreciated.
