A vulnerability in the network stack of MikroTik Version 6.38.5 released 2017-03-09 could allow an unauthenticated remote attacker to exhaust all available CPU via a flood of TCP RST packets, preventing the affected router from accepting new TCP connections.
I think not the product must be fixed, but those people must be fixed.
I agree when there is a security problem something has to be done, but those idiots that just destroy other people’s work and fun
deserve no place on this planet.
We tested several devices (751, hEX lite, CHR - 8x Xeon) and found that they were 100% CPU and down any services on devices (and transit traffic) with this vulnerability. And it does not matter which destination port is specified and what rules are in the firewall. The result is one - device full down.
This wouldn’t help. Such attack on my ROS sill consume all available CPU. Checked on RB951, 2011, hAp Lite and CCR1036.
RST packets didn’t create connection, so firewall rules will just help attackers consume CPU.
We just tested it. Simple firewall rule reduces load by at least 90%. Maybe there is something wrong with your rules? Please post them, so we can check.
The problem is that a firewall rule will knock our CCRs out of fastpath forwarding, thereby severely reducing throughput. Please fix this in software, and preferably offer an update for the current bugfix branch (6.37.x) as well.
Disable these services in “ip services” menu, change ports and use access-from setting. No firewall then. Only the enabled services in “ip services” menu suffer from this load issue.
So using the access-from lists mitigates the problem? That would be awesome because we’re already using that in lieu of firewall rules to keep the devices in fastpath.
A) disable these services and change ports, configure some OOBM access from a special port that has no access to the public networks
B) use firewall
C) Get a more powerful router
If there is an open service, the router will take requests and send answers. There is no way around that. If you have ideas how to “eat the cake and have it” at the same time, let us know
