problem sending email and access some sites
we replaced a broken RB750r2 with a new one with v. 6.43.8 and we set it up the same configuration with a client network connected in vpn to others via IPsec.
but now we have a very strange situation, I describe everything for clarity even if something might not have concern mikrotik:
in that network there are 3 WIN10 computers in domain which can’t access some sites (timeout) e.g. https://bancopostaimpresaonline.poste.it/bpiol1/ , 2 of these clients can receive but can’t send emails on Outlook, this only happens with one provider of which they can’t even reach the webmail site https://webmail.aruba.it (timeout) but they can ping it, the 4th is an XP pc out of domain on which everything works.
all the machines have dynamic IP configuration and the same Outlook configuration.
I tried and using tor browser they can reach the sites, also if I connect the clients directly to the router of the IP provider bypassing the mikrotik everything works.
where should I look to resolve this?
The question and answer are in red.
Probably best to post your config
Here it is, I only hid public ip addresses:
# mar/05/2019 13:50:18 by RouterOS 6.43.8
# software id = TNTL-3CLS
# model = RouterBOARD 750 r2
# serial number = 67D20888227E
add admin-mac=CC:2D:E0:3C:0C:0F auto-mac=no comment=\
    "created from master port" name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mtu=1400
set [ find default-name=ether2 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mtu=1380 \
    name=ether2-master
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
/ip ipsec peer profile
add dh-group=modp1024 enc-algorithm=aes-128 name=profile_1 nat-traversal=no
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=proposal1 pfs-group=none
add name=dhcp ranges=192.168.2.2-192.168.2.200
add name=BIBLIOTECA-pool ranges=192.168.3.2-192.168.3.200
add address-pool=dhcp interface=ether3 name=dhcp
add address-pool=BIBLIOTECA-pool disabled=no interface=bridge1 name=\
    BIBLIOTECA_dhcp
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
/interface l2tp-server server
set default-profile=default enabled=yes ipsec-secret=m4gu4rd4tu!! use-ipsec=\
    required
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
add address=192.168.3.1/24 comment=defconf interface=bridge1 network=\
    192.168.3.0
add address=xxx.xxx.xxx.218/29 interface=ether1 network=xxx.xxx.xxx.216
add address=192.168.2.1/24 disabled=yes interface=ether3 network=192.168.2.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
add address=192.168.2.0/24 comment=defconf dns-server=192.168.100.1,8.8.8.8 \
    gateway=192.168.2.1
add address=192.168.3.0/24 comment=defconf dns-server=192.168.100.1,8.8.8.8 \
    gateway=192.168.3.1
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment=input src-address=192.168.100.0/24
add action=accept chain=input src-address=192.168.1.0/24
add action=accept chain=input in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input connection-state="" dst-port=1701,500,4500 \
    in-interface=ether1 protocol=udp src-address=195.81.178.154
add action=accept chain=forward comment=forward connection-state="" \
add action=accept chain=forward src-address=192.168.1.0/24
add action=accept chain=input dst-port=2200,8291 in-interface=bridge1 \
    protocol=tcp src-address=192.168.3.0/24
add action=accept chain=input dst-port=2200,8291 in-interface=ether1 \
    protocol=tcp src-address=xxx.xxx.xxx.40/29
    protocol=tcp src-address=192.168.1.0/24
    protocol=tcp src-address=192.168.100.0/24
add action=drop chain=input dst-port=80,22,23,2200,8291 in-interface=ether1 \
    protocol=tcp
add action=drop chain=input connection-state=!established,related disabled=\
    yes in-interface=ether1
add action=accept chain=forward connection-state=established,related \
    in-interface=ether1
add action=drop chain=forward disabled=yes
add action=drop chain=input comment="defconf: drop all from WAN" disabled=yes \
    in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=""
    connection-state=invalid disabled=yes
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new disabled=yes in-interface=ether1
add action=accept chain=srcnat comment="VPN Municipio" dst-address=\
    192.168.100.0/24 src-address=192.168.3.0/24
add action=accept chain=srcnat dst-address=192.168.100.0/24 src-address=\
    192.168.2.0/24
add action=accept chain=srcnat dst-address=192.168.1.0/24 src-address=\
    192.168.3.0/24
    192.168.2.0/24
add action=accept chain=srcnat dst-address=192.168.3.0/24 src-address=\
    192.168.100.0/24
add action=accept chain=srcnat dst-address=192.168.2.0/24 src-address=\
    192.168.100.0/24
    192.168.1.0/24
    192.168.1.0/24
    out-interface=ether1
/ip ipsec peer
add address=195.81.178.154/32 exchange-mode=aggressive profile=profile_1 \
    secret=m4gu4rd4tu!!
/ip ipsec policy
set 0 disabled=yes
add dst-address=192.168.100.0/24 proposal=proposal1 sa-dst-address=\
    195.81.178.154 sa-src-address=xxx.xxx.xxx.218 src-address=192.168.3.0/24 \
    tunnel=yes
add dst-address=192.168.1.0/24 proposal=proposal1 sa-dst-address=\
    tunnel=yes
add distance=1 gateway=xxx.xxx.xxx.217
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set winbox address="192.168.100.0/24,192.168.3.0/24,192.168.2.0/24,192.168.1.0\
    /24,xxx.xxx.xxx.40/29"
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=MikroTik
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
any idea?
I would say its your config. (operator error).
For example can you explain what each FW rule you have does
(input, forward and nat)? Or is this simply a copy from work someone else has done???
(I got lost trying to understand them as they are not standard)
They were pre-configured but I tried disable all the deny rules and nothing changed
Any good reason for having set reduced MTU on some particular ether ports?
we low it trying to improve the packets retransmission, if it is wrong I’ll reset it to the default 1500 but the problem was there before.
I’m installing Wireshark to see what is blocked
Well, I think it’s a matter of incorrect configuration settings. Firstly, there is one rule: when something works stably, do not dare to climb to improve it because you will only make it worse. It is necessary to change when the time comes, and there is no need to rush. Try changing your email address. If you had Outlook mail, then try yahoo or gmail. These emails are much more stable and reliable, the more so for the USA and Europe. However, there is still an alternative. You can try to use this service https://tempmail.dev/. Here, you can create temporary emails and use them. Not so difficult, but quite practical and reliable.
