problem sxt lite 2
I bought a sxt lite 2 but refuses to work on ap
What do I do works AP ??
SXT Lite 2 Have RoS Licence Level 3 so not support work as AP.
http://routerboard.com/RBSXT2nDr2
Licence features levels:
thank you brother
but for the license 6 is too expensive , because as well as the purchase of Nanostation m2 much better ..
For the fourth license How do I get it and whether benefit to resolve my problem. ?
level 4 license will get you the ap feature, its only 45us, you can buy it online creating an account at https://www.mikrotik.com/client/
more info at
http://wiki.mikrotik.com/wiki/Manual:License
You can set the mode to “bridge” and the board will work as AP and will allow to connect only one client. With that you can use to make point-to-point connection.
thank you
but 49$ +45$= 94$
High price while the product was SXT2 best specifications and price
Biggest calamity is purchased Elite …
There are license levels. You should read first what they mean before buying…
The problem is that the company’s distributor did not explain The new product Elite
also it can not solve the problem until now, although the problem has two months
thank you alots deanMKD1
