Hello
im using mikrotik RB2011 UiAs-2Hnd in my network
client conect to mikrotik to access internet
the problem is when they connect the vpn , other client cant ping the pc which conect to vpn
no share folder or shared printer work
until connection disconnect
this is some information about my device from terminal command
please help me to fix this problem
thanks
MikroTik LAN IP:
192.168.0.102
LAN DHCP Range:
Lan DHCP Is Set In Windows Server
/ip pool print
NAME RANGES
0 pool1 172.25.20.1-172.25.20.30
1 pool195 172.26.1.1-172.26.1.100
2 poolremote 197.168.0.150-197.168.0.200
3 dhcp_pool1-wifi 192.168.90.100/30
4 hs-pool-3 192.168.0.1-192.168.0.101
192.168.0.103-192.168.0.254
5 TEST-Pool 192.168.0.0-192.168.0.254
/ppp profile print detail
Flags: * - default
0 * name="default" local-address=172.26.1.200 remote-address=pool195 use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=default use-upnp=default address-list="" dns-server=8.8.8.8 on-up="" on-down=""
/ppp secret print detail
[admin@Mikrotik] > /ppp secret print detail
Flags: X - disabled
2 name="username" service=pptp caller-id="" password="password" profile=default routes="" limit-bytes-in=0 limit-bytes-out=0 last-logged-out=oct/14/2017 18:12:24
3 name="username" service=any caller-id="" password="password" profile=default routes="" limit-bytes-in=0 limit-bytes-out=0 last-logged-out=oct/14/2017 15:19:20
4 name="username" service=any caller-id="" password="password" profile=default routes="" limit-bytes-in=0 limit-bytes-out=0 last-logged-out=aug/13/2017 11:46:08
5 name="username" service=any caller-id="" password="password" profile=default routes="" limit-bytes-in=0 limit-bytes-out=0 last-logged-out=oct/14/2017 17:16:10
6 name="username" service=any caller-id="" password="password" profile=default routes="" limit-bytes-in=0 limit-bytes-out=0 last-logged-out=aug/18/2017 09:35:54
/interface pptp-server server print
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: mschap2
keepalive-timeout: disabled
default-profile: default
/ip firewall filter print detail
0 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
/interface ethernet print
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1-MSP 1500 enabled none switch1
1 R ether2 1500 proxy-arp none switch1
2 ether3 1500 enabled none switch1
3 R ether4 1500 enabled none switch1
4 ether5 1500 enabled none switch1
5 ether6 1500 enabled none switch2
6 ether7 1500 enabled none switch2
7 ether8 1500 enabled none switch2
8 ether9 1500 enabled none switch2
9 ether10 1500 enabled none switch2
10 sfp1 1500 enabled none switch1
/ip firewall nat print detail
4 ;;; Internet Access Trough VPN
chain=srcnat action=masquerade src-address=172.26.1.0/24 dst-address=!172.26.1.0/24 log=no log-prefix=""
