Problem to boot: "Loading E"
Hello, I’m trying to use version 3.20 of Mikrotik and finished installing and trying to boot the server crashes in the message “Loading E”. Has anyone experienced this?
use 3.30 or 4.11. Why using 3.20¿?¿? : ?
Aps…
I find it in google..
Our reply is:
You can buy a true license and use 3.30 or 4.11 ; )
Make sure you are using official image or package set, not anything unofficial cracked images.
BR.
Faton
normis has to give us karma for this xD
This ‘Loading E’ plagues even new versions. I think it has something to do with corrupted boot sector or worn out flash possibly.
Try to disable or enable option LBA on HDD in bios
