Problem to compare two values [solved]
Hello, I made this script to find the second value found in the file pagos.txt, what I did was convert it to a string, but I can not make it work properly, I leave the script file and example payments to see if someone can give me a hand to finish
:if ( [/file get [/file find name=pagos.txt] size] > 0 ) do={
   :global content [/file get [/file find name=pagos.txt] contents] ;
   :global contentLen [ :len $content ] ;
   :global lineEnd 0;
   :global line "";
   :global lastEnd 0;
   :do {
         :set lineEnd [:find $content "\n" $lastEnd ] ;
         :set line [:pick $content $lastEnd $lineEnd] ;
         :set lastEnd ( $lineEnd + 1 ) ;
         #If the line doesn't start with a hash then process and add to the list
         :if ( [:pick $line 0 1] != "#" ) do={
          :local entry [:pick $line 0 ($lineEnd -1) ]
          :if ( [:len $entry ] > 0 ) do={
			:set tmpArray [:toarray $line] ;
            :set cliente [:pick $tmpArray 1];
           	:set clienteIP [ /ip address get [/ip address find comment=$cliente] value-name=network ];
            /ip firewall address-list add address=($clienteIP . "/29") comment=$cliente list="PAGOS";
   } while ($lineEnd < $contentLen)
The content of pagos is like this:
180.00,CALANDRIA1691FDO,1
70.00,MZ35D72A,2
The value i need to compare is for example CALANDRIA1691FDO
Bye
Ps: Sorry my poor english
The size of pagos.txt are > of 4096Byte?
If Yes, you can not read them.
Its only a few lines of data, less than 4096
Solved, perform the upgrade to version 6.13 and works properly.
Bye
