problem to get system identity
I cant seem to find out why I’m not getting the value of system identity when I execute this command, in turn I get a blank response:
/system identity get name
[EMPTY]
if I use system identity print, I get:
ROS version: 6.49.7
I just want to get the identity of the router on a variable to add it to a mail subject but it’s not working…
:set mikrotikName [/system identity get name]
Thank you in advance!
Regards
Ramiro
You can take the idea from here https://help.mikrotik.com/docs/display/ROS/Scripting+examples#Scriptingexamples-Generatebackupandsenditbye-mail
What you give with this command on terminal?
/system identity export
You have ALREADY defined the mikrotikName valiable with “:global mikrotikName” or “:local mikrotikName” ???
Show all the script, probably the error is on another place.
