So we have the set of the systems:
System “A” is x86 machine with Atheros 2.4Ghz card set to station mode, PC in shielded and grounded metal box
System “B” is x86 machine with two Atheros 2.4Ghz cards set to ap bridge mode, PC in shielded and grounded metal box.
Antenna to system “A” set to vertical polarization
Antenna to system “C” set to horizontal polarization
System “C” is x86 machine with Atheros 2.4Ghz card set to station mode, PC in shielded and grounded metal box
All have the same config: ROS 3.22, nstreme enabled, enable pools, disable CSMA, framer policy = exact size, framer limit = 4000
System states:
- Link A-B and B-C is idle
System “A”: Signal strength -69, Tx Signal strength -69, Signal to Noise 32, Tx/Rx CCQ 46/62, Tx/Rx Rate 54Mbps/48Mbps, P Throughput 25000
System “B”, card to system “A”: Signal strength -69, Tx Signal strength -69, Signal to Noise 34, Tx/Rx CCQ 58/38, Tx/Rx Rate 54Mbps/48Mbps, P Throughput 29000
System “B”, card to system “C”: Signal strength -65, Tx Signal strength -64, Signal to Noise 36, Tx/Rx CCQ 98/100, Tx/Rx Rate 54Mbps/54Mbps, P Throughput 30000
System “C”: Signal strength -64, Tx Signal strength -65, Signal to Noise 37, Tx/Rx CCQ 100/98, Tx/Rx Rate 54Mbps/54Mbps, P Throughput 30000
- Link A-B with low traffic
System “A”: Signal strength -69, Tx Signal strength -73, Signal to Noise 30, Tx/Rx CCQ 40/64, Tx/Rx Rate 18Mbps/24Mbps, P Throughput 8000
System “B”, card to system “A”: Signal strength -73, Tx Signal strength -69, Signal to Noise 30, Tx/Rx CCQ 64/30, Tx/Rx Rate 24Mbps/18Mbps, P Throughput 18000
- Link A-B with high traffic
link form A to B disconnects every second
- Link B-C with low or high traffic
System “A”: Signal strength -69, Tx Signal strength -73, Signal to Noise 30, Tx/Rx CCQ 40/64, Tx/Rx Rate 24Mbps/36Mbps, P Throughput 11000
System “B”, card to system “A”: Signal strength -73, Tx Signal strength -69, Signal to Noise 30, Tx/Rx CCQ 64/30, Tx/Rx Rate 36Mbps/24Mbps, P Throughput 21000
- Link B-C is off
System “A”: Signal strength -68, Tx Signal strength -67, Signal to Noise 32, Tx/Rx CCQ 96/98, Tx/Rx Rate 54Mbps/54Mbps, P Throughput 30000
System “B”, card to system “A”: Signal strength -67, Tx Signal strength -68, Signal to Noise 33, Tx/Rx CCQ 98/97, Tx/Rx Rate 54Mbps/54Mbps, P Throughput 30000
We tryed to change frequency (example A-B 2.3Ghz and B-C 2.5Ghz), 10/5Mhz bands, A-B only 802.11b and B-C only 802.11G bands, lowed TX power, shortest pigtails, shields on WiFi cards - all doesn’t affect to degradation of A-B link
