Dear, I am having problems to update an RB2011UiAS (mipsbe) with v6.42.6 and same firmware
Previously to experiment I had installed some ipv6 and advanced packages, I think that’s where I “ruined” it
The problem is that it fails to update and ignores the reboot.
I only see the pkg in / file and nothing else.
I would also like to know how to permanently remove the extra pkg that I add, since I can not uninstall them.
I never have something like that and I can not find a guide on how to solve it, maybe because I’m looking bad.
thank you very much
No suggestion?? how do you think I can clean this list?
/system package print
Flags: X - disabled
NAME VERSION SCHEDULED
0 X advanced-tools 6.42.6
1 X ipv6 6.42.6
2 routeros-mipsbe 6.42.6
3 system 6.42.6
4 X ipv6 6.42.6
5 wireless 6.42.6
6 hotspot 6.42.6
7 dhcp 6.42.6
8 mpls 6.42.6
9 routing 6.42.6
10 ppp 6.42.6
11 security 6.42.6
12 X advanced-tools 6.42.6
BR
Hello
Maybe you did but have you tried removing the extra packages instead of just disabling them?
Are you using the packages of the right architecture for the upgrade?
Usually, when upgrade fails, it’s because you’re using the wrong files or an older version. Are there messages in log after reboot?
Sent from Tapatalk
Hi Alain, thank you very much for your response.
You know I tried to do it on repeated occasions, but it did not work for me and the packages keep coming back.
The procedure is: Unwrap it, it is programmed for the reboot … and after restarting it remains the same as before
I do not report anything in the logs, at least nothing of interest …
Can you think of something?
BR
Weird…
Maybe a good backup / export, then netinstall.
Nothing out of the ordinary in your config, like scripts you never did?
Sent from Tapatalk
