Problem upgrading license from lv 3 to lv 4 w/extra channels
I got problem upgrading rb411 v3.3 comes with level 3 to level 4 with extra-channels
This is level 3 license key :
-----BEGIN MIKROTIK SOFTWARE KEY------------
jA6BWZe/wx9W+IqQDMYkiZh0iS6oSggLRwpLRQYdnok9
zoUXh8FjLu99ovEpt5eAxHUTo+4VUfhXyfKvvg1tnC==
-----END MIKROTIK SOFTWARE KEY--------------
This is level 4 license key :
1Q3B2NoW7Bty976+QY7aFVxAJBrDhXstTSHijywd5eNK
B2dJyhGMaZUfbglKOX+5JVG5uqnALkC6I3mcmGcoqA==
This is extra-channels key :
MCEE127inqVuGCPtsCkIEXUPEw6LHgLE5G+NuoJC2n7s
/IZrQWX9NlkIbYjWDrxqVR1HpGFdfIInuLCvH4xMSB==
Case 1 :
  • board is level 3
  • paste level 4 key
  • reboot
  • board is now level 4
  • paste extra channels key
  • reboot
  • board is now level 3 with extra-channels
Case 2 :
  • board is level 3
  • reboot
  • paste level 4
  • reboot
  • board is now level 4 without extra-channels
What’s wrong? the board or the key?
key is purchased from pre-paid account…
wrong soft-id for extra license?
soft id is WIU9-LTT
I suggest you check with support@mikrotik.com, maybe they made a mistake.
  1. it’s not possible to upgrade license level. you simply need to make a new purchase with the appropriate level selected.
  2. as I see that is not the problem. you have 3 keys - the original L3, the upgraded L3+CF and a new L4 key. You need to upgrade the L4 key to CF to solve the problem
