I have a MT in bridge mode with ques for each IP address a /23. This MT has worked great untill the last week. Two customers do not seem to be limited even though there que is like all others.
Ques are HTTP, other, and P2P. The P2P, and HTTP limit correctly. The “other” does not seem to limit on two customers. I have changed the rate to choke them down and they still get what there is availible on the T1.
I used the Transperent shaping procedure in the WIKI to a tee. This unit has worked great, and only two customers seem to have a way to get around this.
Thoughts?
One more thing when I use torch I see a single IP that this customer is trasmitting with at a speed greater than what is allowed.
