Problem WDS mode
Hello i have mikrotik router os 2.9.6 & working fine all cable network & wireless lan cards network but whats problem wireless AP to wireless lancards service is ok but AP to AP wds mode networking is ok client AP to Main Server Ap ping reply time is 1 to 2 ms but internet is not working Mikrotik dhcp gives ip address & i also masquerade the firewall but internet is not working with AP to AP mode i have 5 connection in there side but i face the problem anyone have idea ? plz tell me thanks to advance & sory for my bad English
Dear Atif,
If you have enabled masquerading then it should work, there must be something wrong in your settings. What are the ARP settings on your interface is it “reply-only” if yes then you will have to set dhcp to add ARP for leases.
By the way where are you from PK, Khi.
I am from Rawalpindi PK dear all things done look this picture
Is there internet access for the WLan clients that are connected to the “My Wlan Acess Point”?
no wireless lancard clients
