My setup is like this
on ether1 I have hotspot running and all users function without problems.
We are currently into transition from hotspot to PPPoE.
I do that by creating EoIP tunnel and bridging it with ether1.
Users that go via that tunnel to PPPoE server have internet access without a problem.
But users who remained on hotspot have troubles accessing certain websites, like kurir.rs, blic.rs and making calls over Viber.
This problem was first noticed on RB1100AHx2 with 6.27RoS. And I resolved the issue with downgrading to 5.26.
Now same is happening on RB433AH on 6.28. I think that this is a bug because downgrading ROS makes problem dissapear.
But this router is on very remote location so I’m reluctant to downgrade because couple of times after downgrading router got stuck in reboot loop.
Can someone help me troubleshoot this and solve it.
I will provide any aditional info needed.
I narrowed down problem to http websites. When EoIP tunnel and ether (or wifi) interface are in same bridge and there is hotspot running on that bridge this problem occures. I’ve found a workaround by adding a web proxy, but it’s a bit too resource intensive.
I’m not sure on this, but it looks like this problem appears when there is more than one hotspot on device. My guess is that some hotspot firewall or nat rule are messed up.
After doing some more research, it looks like adding EoIP to bridge does something with MTU, and that’s why some websites don’t work. I’ve found this on some other forum, but last post was from 20 days ago and I don’t know what solution is, other than trying to change MTU values on EoIP, bridge and ether1. Any idea is welcome.
I’ve just checked, and yes, mtu on bridge was lowered to 1458. At the moment I do not have physical access to test if that would fix it, but in the morning I will try to see if it will fix my problem and thus remove need for firewall based solution.
