Problem when changing IP on RB951-2n using Webfig 6.29.1
Hi
I have used WebFig 5.25 for a while and now upgraded to 6.29.1 on a separate box. Then I configured that to reflect the currently “active” router. Once ready I just entered the IP-address of the active box in the “Quick set” of the extra box and applied it - and of course changed the active box to another IP as well :slight_smile:
It comes up fine - and the core functionality (DNS, router, firewall) seem to work.
But I have all sorts of problems using WebFig! From my Javascript console I see errors like:
http://router.mydomain.dk/webfig/progress.gif Failed to load resource: net::ERR_CONNECTION_RESET
http://router.mydomain.dk/jsproxy Failed to load resource: net::ERR_CONNECTION_RESET
The latter one comes MANY times (POST requests) and nothing really works…
First I thought I had “tightened” the firewall too much and therefor scrapped everything and set it up again (after a reset configuration) - and looking at the javascript console during this process. No errors.
As soon as I open it with the new IP-address it goes berserk. Using the IP address directly (not reusing the host name) gives same result. Clearing browser history makes no difference. I have even tried to change the DNS for the old hostname to the new one (so accessing it via the host name that worked prior to changing the IP.
Any ideas appreciated!
/John
Never mind.
I gave up, gave the router its original IP, modified all DHCP and DNS (etc.) settings and rebooted all other equipment.
So I’ll just leave this issue in the “unsolved” pile :wink:
/John
