Problem when trying to move simple queues
Good afternoon everyone, I am trying to move a queue to first position through php api, but sometimes the script removes all queues rather than move it, someone could give me a hand with this script? routeros version routeros 5.2x
very grateful to all!
$API->write(‘/queue/simple/getall’, false);
$API->write(‘?name=’ . $name);
$ARRAY = $API->read();
$ARRAY = $ARRAY[0];
$API->write(‘/queue/simple/move’, false);
$API->write(‘=.id=’ . $ARRAY[‘.id’],false);
$API->write(‘=destination=*0’,true);
$API->disconnect();
The ID of the first item probably isn’t “*0”. That is, you’d need to take that out of the print too. In the “/queue/simple” menu in particular, you can also target by name BTW.
A move command should never be removing anything though.
Thank you friend, you could help me with this problem, I need to move a queue to the top, how would the script below?
$API->write('/queue/simple/getall', false);
$API->write('?name=' . $name);
$ARRAY = $ARRAY[0];
$API->write('/queue/simple/move', false);
$API->write('=.id=' . $ARRAY['.id'],false);
$API->write('=destination=*0',true);
$API->disconnect();
If you don’t know the name of the first queue in advance, you need to get it with a print.
After you have that, you just supply it as the “destination” argument.
In terms of actual code… I feel really awkward working with that client, especially when with mine, it’s simplified to
$util->changeMenu('/queue/simple');
$util->move($name, 0);
(see this for a full code sample)
I guess with that, it would something among the lines of
$ARRAY = $ARRAY[0];
$API->write('=.id=' . $name,false);
$API->write('=destination=' . $ARRAY['.id'],true);
$API->disconnect();
