Problem while changing pppoe-client comment
When I’m try to change pppoe-client comment I’m getting reconnecting (“disconnected”, “initializing”, “connecting”, “authenticated”, “connected”)… any idead why?? and how to fix it?
you change a setting, and it would then reintitialise. i think its normal behavior.
Indeed its happening i have seen that many times. I wonder also why. Comment is not a setting!
damm, I’m tring you create wan monitor script, if there is no internet change comment to “disabled at ” and when the internet back change comment to “enabled at ” there is no problem when there is no internet, but when the internet back and the status disabled, he just should change the status and it’s reconnecting :frowning:
comment change the settings. it should not be like this - and should be reported as a bug of feature request.
