problem wiht pcc
hi all
i have a problem with pcc. i have 3 isp. with static ip.
1)
ip 10.21.68.x1/24
get way 10.21.68.1
dns1 217.10.32.4
dns2 217.10.36.5
ip 188.65.238.x2/24
get way 188.65.238.1
dns1 195.135.239.162
dns2 195.135.239.179
ip 192.168.0.8/24
getway 192.168.0.1
dns 192.168.0.1
I’m using pppoe server. I have make pcc as well. but problem with dns. Where can i put these all dnss ?. Windows just can receive two dns s. so sometimes some sites canot open. What can I do ?. plizz help me…thx
use another independent DNS provider, such as Google or OpenDNS?
thx for answer
i tried. but not working… :frowning:
what exactly not working?..
In Winbox go to IP.DNS and you can add multiple DNS servers there. The router will look at each of these for requests. Make sure you enable “Allow Remote Requests” and your clients send DNS to Mikrotik which then checks each of your downstream DNS providers.
Or from CLI for example :-
[admin@MikroTik] ip dns> set servers= 217.10.32.4,217.10.36.5,195.135.239.162,195.135.239.179 allow-remote-requests=yes
site canot open…
i m using v 3.30. there has just 2 dns…
why? is it just DNS resolution error, or traceroute starts to show timeouts after the router, or something else?..
AFAIR upgrade to v5 is free, just upgrade first to v4.17, then v5.14
