Hello, I ordered sq ax and I have a problem, despite the super channel set, I do not see other transmitters at all. I checked the settings on the transmitters in the ac ross.6.49.19 standard, I have the country Poland, the channels on the list match, unfortunately in the scan they do not show up on the list as if they were not known at all. Any problem with new devices in ax?
OK, I’m not sure I understand what the problem actually is …
What are you checking exactly ? Where ?
You can not simply compare AC ROS6.49.19 with AX ROS7.something.
Without any further info, SQ AX is an outdoor device.
Maybe your problem is already there ? Quite a bit of 5GHz channels are restricted from use on an outdoor device and ROS7 really reinforced that restriction.
Hello.
But these are external transmitters. Instead of sq ax I connect sq ac to the client and it shows all transmitters on the list but in sq ax it doesn’t show any
You need to give A LOT more info for anyone to be able to help you …
Or put it otherwise: help us help you. You’re not helping right now…
- transmitters: what type of devices ? What frequencies do they use ?
- AC: what config does it have ? Post here between code quotes
- AX: what config does it have ? Post here between code quotes
transmitters - rb922 AC - Country poland chanel 5520
AC- Country poland - show all ssid not only my transmitter
AX- Country poland (superchanel) no show any transmitter (cheack 2 difrent device)
show ssid where? post screenshots of the problem, like asked above already
In interface wlan1 scan
