Problem witch troughput over omnitik.
at first, i am very sorry for my english…will try my best.
I would like to ask you if anyone encountered this problem: CLIENT(sxt)<----->OMNITIK<---->Licensed Radio<—>main router
Btest from Omnitik to client is OK (18Mbits) from main router to Omnitik is OK too but when i am doing Btest from Min Router to Client the speed is max 5-8Mbits.
Many thanks for any response.
p.s.: I tried turning On/Off all firewall rules etc..
What distance from ap and client?
it is cca. 300-400m
Look how match signal you have.
You must not more signal have than -60 dB
If less than -60 example -40
Reduce the power output from the link
Signal is OK … it worked flawlessly before.
thank you for response
Is the licensed link directly connected to the omnitik?
We had a similar situation where we had to enable Flowcontrol on the licensed link and the switches between them and the other devices. Some links seem to have big buffers which causes the “buffer bloat” problem if they can’t deliver the packets at wire speed.
Just a thought from my side… :wink:
  • Mat
