I have a issue we have a CPE configured as Client and it is connected to RB411AH LAN port and RB411AH is configured as Hotspot on Wlan1.
Problem is: In ideal CPE registered on RB433AH showing P Throughput 10500kbps, CCQ 58%, signal 68dbm to 75dbm max.
But when any data transfer take price then its CCQ drops from 58% to 2% or 5% only, and P Throughput drops to just 50kbps to max 300kbps and signal remains good.
Setup: RB433AH connected to 50Mbps on Lan1 and having hotspot configured on Wlan1 with 16dbi Omani antenna as BTS. second location is CPE(400mw+18dbi integrated antenna)-RB411AH-wlan1+Omani 15dbi. (Second location is connected to first location) it is installed to increase the coverage area.
the location u r using has interference on the channel selected by u. Secondly the client is sending more upload traffic and using too many simultaneous sessions.
The remote location is not in use no subscribers are connected its only a stand alone connected with a CPE=>RB411AH=>Subscribers
Problem is BTS to CPE=>RB411AH (P Throughput is low and and CCQ also reduce when ever we do the bandwidth test to that RB411AH CCQ come to 1% to 2% or 5% only)
BTS is 433AH with 5.2 earlier and now upgraded to 5.3.
