I try RC3 version and after time (15min - 3 hours) my router was break down ! I can’t ping it. I try it on 2 PC - whitch work ok with ver. 2.9.xx with same configuration !
I uninstalled Dude and calea package because it hang my MT pernamently !
My router hang again! It’s unstable!
I had the same problem recently with a critical access point, upgraded to RC4 and its been fine since. It appears to have also “fixed” those pesky “…extensive data loss” issues.
I put new configuration - manualy (not import) - still problem with 100% CPU usage !
Please, repair this important bug!
Why mikrotik doesn’t have resource monitor by packages?
I need see how many memory, cpu take some packages, for example:
CPU MEM
dude 10% 1250kb
dhcp 1% 200kb
system 25% 125kb
This monitoring may resolve many broblems, I think so.
I think I told in one of the topics, that when you have a dude package after the reboot it loads all the snmp mibs and that could take few minutes - cpu 100% you should wait few minutes.
I’m seeing this problem but it only happens after I login to the router via SSH or at the console. I can quick jump into resources and it sits at 2-5% then after another command or 2, it shoots to 100% (can tell because my typing is very slow). The commands are just print or monitor commands, no config changes. I’m seeing this in RC4 aswell.
This appears to be a problem with the system formatting your proxy drive regardless whether the proxy is enabled or disabled. I let mine go for about an hour and now its fine. I had a second 20gb drive for proxy attached to the system though.
