Problem with 411
we have established a Rf link for the distance of less than 2 kms. We have used 411 with R52H card in both sides with 2.4 grid antenna.
the signal strength is 58 and connectivity is 36 to 48 mbps. The main problem in this link is the bandwidth. We couldnt get even 300 kbps. Please help in overcoming the mentioned problem. Expecting your suggestions and guidelines
Post a screenshot of wireless, registeration, signal tab from which it will tell us RX/TX CCQ, SNR, alignment, etc
yes, need more info for resolve the problem!
check polarity of antennas.
They should be both vertical or horizontal. May be H poarization gives better throughput in noisy envoirment.
Try to use a less crowded channel
What are details required?
