Hi to all,
I have two RB433 with two radios. One radio is 2.4 ghz and it is working just fine. Another one is 5.4 setup as WPA2. On one RB as ap-bridge and on another one as station (I’m trying to bridge two networks) Antennas for 5 ghz is omnidirectional 5 db. The distance is just my working space 5 meters.
I put one RB in one corner of the room and another one in another corner of the room. I have no connection. If I put them close I have connection. Is this normal or something is wrong with my radio cards (R52HN). In my opinion 5 db antenna should be just fine for that distance. I’m trying to test before I put in place. I’m planing to replace omni antennas with panel 23 db (distance is around 2 km).
Please advice or share your experience etc.
Thanks,
P.S. How to test is R52Hn is still good?
