Hello everyone
Updated to 7.16.2
Got a big bunch of Big Problems. After adding static routes for my WG tunnels, all my WG tunnels fall off. HAP Model AC2
Well … and the question is?
Has anyone encountered this? So what should I do? I’m not a great expert in these matters. Got into big trouble. I don’t know what to do.
Well, you set the first step.
Can you show your config, so we can have a look at your current settings?
/export file=anynameyoulike
Run above command from a terminal, after executing there will be a file.
Copy the content, remove serial and any other private info and post here between code tags by using the </> button.
That was my first reaction too when I approved that post ![]()
OP
post your config as requested, provide a bit more detail on how things fit in the larger picture and we can work from there.
