Problem with a dual nstream
I am having the following issue with a dual nstream network. I upgraded from v5.26 to v6.42.3 and the dual stream link stopped working so I reset to factory defaults everything and reconfigured both end points from scratch. I followed the how to guide as described (https://wiki.mikrotik.com/wiki/Nstreme_dual_Step-by-Step) but nothing works. The nstream seems up and running however no packets are routed from one end to the other.
Here are my ROS configs for both ends:
END 1 export:
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode channel-width=40mhz-turbo disabled=no frequency=5860 frequency-mode=superchannel \
    mode=nstreme-dual-slave preamble-mode=short scan-list=5860,5920 ssid=WIFIH tx-power=3 tx-power-mode=all-rates-fixed
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode channel-width=40mhz-turbo disabled=no frequency=5920 frequency-mode=superchannel \
    mode=nstreme-dual-slave preamble-mode=short scan-list=5860,5920 ssid=WIFIV tx-power=14 tx-power-mode=all-rates-fixed
/interface wireless nstreme-dual
add disabled=no framer-policy=exact-size name=nstream1 remote-mac=00:11:11:11:11:11 rx-band=5ghz-a rx-channel-width=40mhz rx-frequency=5920 rx-radio=wlan2 \
    tx-band=5ghz-a tx-channel-width=40mhz tx-frequency=5860 tx-radio=wlan1
add bridge=bridge1 interface=nstream1
add address=1.1.1.1/24 interface=bridge1 network=1.1.1.0
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/system identity
set name=ap-1
END 2 export:
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode channel-width=40mhz-turbo disabled=no frequency=5920 \
    frequency-mode=superchannel mode=nstreme-dual-slave preamble-mode=short scan-list=5860,5920 ssid=WIFIV tx-power=10 tx-power-mode=\
    all-rates-fixed
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode channel-width=40mhz-turbo disabled=no frequency=5860 \
    frequency-mode=superchannel mode=nstreme-dual-slave preamble-mode=short scan-list=5860,5920 ssid=WIFIH tx-power=6 tx-power-mode=\
    all-rates-fixed
add disabled=no framer-policy=exact-size name=nstream1 remote-mac=00:22:22:22:22:22 rx-band=5ghz-a rx-channel-width=40mhz \
    rx-frequency=5860 rx-radio=wlan2 tx-band=5ghz-a tx-channel-width=40mhz tx-frequency=5920 tx-radio=wlan1
add address=1.1.1.2 interface=bridge1 network=1.1.1.0
/ip service
/system identity
set name=ap-2
Nstream monitor seems to be working.
interface wireless nstreme-dual monitor 0
  rx-signal-strength: -50dBm
  tx-signal-strength: -52dBm
             rx-rate: 108Mbps
             tx-rate: 108Mbps
           connected: yes
             packets: 4645,168
               bytes: 305939,9968
              frames: 3989,2163
         frame-bytes: 472354,222740
           hw-frames: 15917,6151
      hw-frame-bytes: 952565,382260
  tx-retries-timeout: 9738
     tx-retries-lost: 31
         rx-bad-seqs: 0
       rx-duplicates: 0
However nothing is routed:
[admin@ap-1] ping 1.1.1.2
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 1.1.1.2                                          timeout
    1 1.1.1.2                                          timeout
    2 1.1.1.1                             84  64 967ms host unreachable
    3 1.1.1.2                                          timeout
    4 1.1.1.2                                          timeout
    5 1.1.1.1                             84  64 977ms host unreachable
    6 1.1.1.2                                          timeout
    7 1.1.1.2                                          timeout
    8 1.1.1.1                             84  64 977ms host unreachable
    sent=9 received=0 packet-loss=100%
Any ideas?
In configuration of End2, change
to
add address=1.1.1.2**/24** interface=bridge1 network=1.1.1.0
If it does not help, post also /ip firewall export from both ends.
Sorry about that. This is just a typo error. It actually is 1.1.1.2/24 (I have edited the real IPs/MACs and changed them).
There is no firewall anywhere. This is the whole actual configuration.
The official Mikrotik response to this issue was that nstream dual is no longer supported in latest ROS versions and they have no plans to do so in the future. I hope this may save a few people some time trying to fix a known and broken ROS feature. This broken and obsolete feature should have been documented somewhere that is no longer maintained and should have been removed from ROS. It would save lots of time to many of us.
