Problem with Advertise option
The issue I am experiencing is this:
I have a Mikrotik server with which I share Internet. On the same server I want to add Advertisement Redirections to certain URL’s every so often.
I know I should use the option “Advertise” and type the URL in the “Advertise URL” field within “Advertise tab” in the User profile section.
But when I test if it works, the PopUp never comes up. I’m using the version 4.2 on a RB600
I hope someone has any solution for this problem.
Regards!!!
make sure your browser is not blocking the popups. also, show us your advertise configuration
I have same problem like that i’m using RB1000 my advertise setting like in my post http://forum.mikrotik.com/t/advertise-problem/33915/1
