problem with atheros AR5212 PCI 2.4ghz
I just installed fresh mikrotik and new card.. and i see it in devices in driver section but no in interfaces… I was plug card in other pc same mikrotik software same problem fresh installation but nothing.
any help pls :confused:
thanx
Which MikroTik RouterOS version do you have?
Are you able to get the card working on any other router?
no i didnt try card in any other router only on windows pc it works there… i was trying on 2,9 and some newer but same results then i changed mine p3 install everything on p4 board same… problem is in card i just used mine friend some d link card with atheros chipset works great…
thx
TEW-443PI card something not ok… should work but :frowning: no…
