I have a problem with BGP. So, next config on my Mikrotik (3.17 ver.):
/routing bgp instance print
Flags: X - disabled
0 name=“default” as=65530 router-id=0.0.0.0 redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter=“” client-to-client-reflection=yes
ignore-as-path-len=no
1 name=“company” as=22220 router-id=10.1.1.253
redistribute-connected=no redistribute-static=no redistribute-rip=no
redistribute-ospf=no redistribute-other-bgp=yes out-filter=“”
client-to-client-reflection=no ignore-as-path-len=no
/routing bgp peer print
Flags: X - disabled
0 name=“Catalyst” instance=company remote-address=10.1.7.129
remote-as=22221 tcp-md5-key=“” nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=255 in-filter=catalyst_in
out-filter=company_out address-families=ip default-originate=never
1 name=“reg_net” instance=company remote-address=10.1.5.81
remote-as=22222 tcp-md5-key=“” nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=255 in-filter=reg_net_in
2 name=“par” instance=company remote-address=10.1.1.14
remote-as=22223 tcp-md5-key=“” nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=255 in-filter=par_in
out-filter=par_out address-families=ip default-originate=never
3 name=“reg_world” instance=company remote-address=10.1.5.77
route-reflect=no hold-time=3m ttl=255 in-filter=reg_world_in
4 name=“vlad” instance=company remote-address=10.1.1.74
remote-as=22225 tcp-md5-key=“” nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=255 in-filter=vlad_in
out-filter=stat_out address-families=ip default-originate=always
/routing filter print
Flags: X - disabled
0 chain=reg_world_in prefix=0.0.0.0/0 invert-match=no action=accept
set-distance=100 set-bgp-local-pref=110
1 chain=reg_world_in invert-match=no action=discard
2 chain=reg_net_in prefix=!0.0.0.0/0 invert-match=no action=accept
set-distance=200 set-bgp-local-pref=199
3 chain=catalyst_in invert-match=no action=accept set-distance=199
set-bgp-local-pref=200
4 chain=company_out prefix=10.1.1.0/23 invert-match=no action=accept
5 chain=company_out invert-match=no action=discard
6 chain=par_in prefix=10.1.3.0/23 invert-match=no action=accept
set-distance=198 set-bgp-local-pref=201
7 chain=par_in invert-match=no action=discard
8 chain=par_out prefix=10.1.1.0/23 invert-match=no action=accept
9 chain=par_out invert-match=no action=discard
10 chain=stat_out prefix=0.0.0.0/0 invert-match=no action=accept
11 chain=stat_out invert-match=no action=discard
12 chain=vlad_in invert-match=no action=discard
Mikrotik receive default from “reg_world”, but is not advertise it to peer “vlad”:
[admin@MikroTik] > /routing bgp advertisements print vlad
PREFIX NEXTHOP PEER AS-PATH ORIGIN LOCAL-PREF
[admin@MikroTik] >
If I disable out-filter for “vlad”, Mikrotik advertise all prefixes (for example, prefixes received from peer “Catalyst”) except default. If I add default static route to route list and set “redistribute-static=yes”, Mikrotik advertise all static routes except default. Help me please.
