Problem with BGP and vrf
I’m not able to get bgp to work with vrf. I’ve been able to get bgp working and I receive a route to 192.168.128.0/22 that I’m testing with.
[admin@MikroTik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          10.10.1.1                 1
 1 ADC  10.10.1.0/24       10.10.1.2       ether5                    0
 2 ADC  10.200.1.0/30      10.200.1.1      ether1                    0
 3 ADC  10.250.15.1/32     10.250.15.1     loopback0                 0
 4 A S  10.250.15.2/32                     10.200.1.2                1
 5 ADb  192.168.128.0/22                   10.250.15.2              20
 6 A S  192.168.132.0/22                   Null0                     1
But when I try to add vrf to the mix my bgp peer stays in the connect state. Here is my configuration:
[admin@MikroTik] > /interface export
# feb/03/2014 10:19:54 by RouterOS 6.7
# software id = 6386-7BZW
add name=Null0
add name=loopback0
[admin@MikroTik] > /routing bgp exp
# feb/03/2014 10:20:00 by RouterOS 6.7
/routing bgp instance
set default disabled=yes
add as=65001 client-to-client-reflection=no name="eBGP Test" router-id=10.250.15.1
/routing bgp instance vrf
add instance="eBGP Test" routing-mark=INET
/routing bgp network
add network=192.168.132.0/22 synchronize=no
/routing bgp peer
add instance="eBGP Test" keepalive-time=10s multihop=yes name="Cisco 1811" remote-address=10.250.15.2 remote-as=65000 ttl=2 update-source=loopback0
[admin@MikroTik] > /ip add print
 #   ADDRESS            NETWORK         INTERFACE
 0   10.10.1.2/24       10.10.1.0       ether5
 1   10.250.15.1/32     10.250.15.1     loopback0
 2   10.200.1.1/30      10.200.1.0      ether1
[admin@MikroTik] > /ip route print
 0 ADC  10.200.1.0/30      10.200.1.1      ether1                    0
 1 ADC  10.250.15.1/32     10.250.15.1     loopback0                 0
 2 A S  10.250.15.2/32                     10.200.1.2                1
 3 A S  192.168.132.0/22                   Null0                     1
 4 A S  0.0.0.0/0                          10.10.1.1                 1
 5 ADC  10.10.1.0/24       10.10.1.2       ether5                    0
[admin@MikroTik] > /ip route export
# feb/03/2014 10:20:39 by RouterOS 6.7
add distance=1 dst-address=10.250.15.2/32 gateway=10.200.1.2 routing-mark=INET
add distance=1 dst-address=192.168.132.0/22 gateway=Null0 routing-mark=INET
add distance=1 gateway=10.10.1.1
/ip route vrf
add interfaces=ether1,loopback0 routing-mark=INET
[admin@MikroTik] > /ip route print detail
 0 ADC  dst-address=10.200.1.0/30 pref-src=10.200.1.1 gateway=ether1 gateway-status=ether1 reachable distance=0 scope=10 routing-mark=INET
 1 ADC  dst-address=10.250.15.1/32 pref-src=10.250.15.1 gateway=loopback0 gateway-status=loopback0 reachable distance=0 scope=10 routing-mark=INET
 2 A S  dst-address=10.250.15.2/32 gateway=10.200.1.2 gateway-status=10.200.1.2 on INET reachable via  ether1 distance=1 scope=30 target-scope=10 routing-mark=INET
 3 A S  dst-address=192.168.132.0/22 gateway=Null0 gateway-status=Null0 reachable distance=1 scope=30 target-scope=10 routing-mark=INET
 4 A S  dst-address=0.0.0.0/0 gateway=10.10.1.1 gateway-status=10.10.1.1 reachable via  ether5 distance=1 scope=30 target-scope=10
 5 ADC  dst-address=10.10.1.0/24 pref-src=10.10.1.2 gateway=ether5 gateway-status=ether5 reachable distance=0 scope=10
