i’ve some abuse complaints from DC. and i should fix spamming problem.
i want to block all ports except some. i run these below but after connectiong (VPN) , there is not internet :
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=21
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=22
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=80
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=110
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=443
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=5050
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=8080
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=8291
add chain=forward disabled=no action=drop in-interface=LAN
please help me
i wanna prevent spam, viruses, trojans, bit torrentz …
thanks
fewi
May 17, 2011, 2:31pm
3
You’re not permitting DNS - could that be why you “don’t get Internet”?
thanks for your reply.
which ports should i allow?
fewi
May 17, 2011, 2:34pm
5
The ports DNS runs on.
DNS runs on udp/53 and sometimes on tcp/53.
add chain=forward disabled=no action=accept in-interface=LAN protocol=tcp dst-port=53
add chain=forward disabled=no action=accept in-interface=LAN protocol=udp dst-port=53
correct, yes? are these enough to prevent spam?
thanks
i have a bugger who not only downloads but even uploads via bit torrents and dat fellow tells that his download gets slow if he contains the uploads. Is it so??
I want to drop his uploads. what to do…
fewi
May 17, 2011, 2:47pm
8
What are you trying to block? Spam (email), or bittorrent?
What you have should be sufficient for both, really, unless someone runs email to bittorrent through the ports you’re permitting.
add chain=forward disabled=no action=accept in-interface=External protocol=tcp dst-port=53
add chain=forward disabled=no action=accept in-interface=External protocol=udp dst-port=53
add chain=forward disabled=no action=accept in-interface=External protocol=tcp dst-port=43
add chain=forward disabled=no action=accept in-interface=External protocol=udp dst-port=43
no internet again,
any solution please?
when i enter :
add chain=forward disabled=no action=drop in-interface=External
no internet
normis
May 18, 2011, 11:32am
10
why are you entering this rule ?
this rule will block the internet. that is it’s only purpose
