Problem with burst!!
I had already times written, that I have a problem with the burst time in simple queues.
My problem is that I can’t limiting clients with burst time.
My config:
Name - xxx
Target Address - 192.168.2.201/32
Limit At - --/–
Max Limit - 262144/524288
Burst Limit - 393216/786432
Burst Threshold - 26214/52428
Burst Time - 65/75
When i start a download, i can download with 500 - 530 Kbps (25Kpbs pload).
I found out, that the bandwith is how the BURST LIMIT, but only for one second, although I have set it to 75 second.
Can me help somebody??
Here you can find explanation of burst function:
http://www.mikrotik.com/docs/ros/2.9/root/queue||0.36746536877573943
You can calculate when max-limit is used.
thanks for your answer.
I have read the manual, but never canche.
I have made the same setup, but after 1-2 second I have the max. Limit.
Why is it so??
I need the feature urgently!!
Please help me!! :confused:
Try to increase burst-threshold for example, it should influence on your bandwith.
If you understand all functions meaning, you should pass this problem. :sunglasses:
OK, work fine.
thanks
