Problem with CCR2004-1G-12S+2XS and SFP+ module
Hi all, I have a CCR2004-1G-12S+2XS device and TP-Link SM5310-T SFP+ module but It doesn't work.
With auto-negotiation I doesn't have link:
interface/ethernet/monitor 1
status: no-link
auto-negotiation: done
supported: 10M-baseT-half
10M-baseT-full
100M-baseT-half
100M-baseT-full
1G-baseT-half
1G-baseT-full
1G-baseX
2.5G-baseT
2.5G-baseX
5G-baseT
10G-baseT
10G-baseSR-LR
10G-baseCR
sfp-supported: 1G-baseX
10G-baseSR-LR
advertising: 1G-baseX
10G-baseSR-LR
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP/SFP+/SFP28/SFP56
sfp-connector-type: LC
sfp-encoding: 64B/66B
sfp-vendor-name: TP-Link
sfp-vendor-part-number: SM5310-T(UN)
sfp-vendor-revision: 2.0
sfp-vendor-serial: 2256004R00434
sfp-manufacturing-date: 25-06-09
sfp-temperature: 41C
sfp-supply-voltage: 3.279V
sfp-tx-bias-current: 0mA
eeprom-checksum: good
eeprom: 0000: 03 04 07 10 00 00 00 00 00 00 00 06 67 00 00 00 ........ ....g...
0010: 00 00 00 00 54 50 2d 4c 69 6e 6b 20 20 20 20 20 ....TP-L ink
0020: 20 20 20 20 00 00 00 00 53 4d 35 33 31 30 2d 54 .... SM5310-T
0030: 28 55 4e 29 20 20 20 20 32 2e 30 20 00 00 00 18 (UN) 2.0 ....
0040: 00 1a 00 00 32 32 35 36 30 30 34 52 30 30 34 33 ....2256 004R0043
0050: 34 20 20 20 32 35 30 36 30 39 20 20 68 f0 00 f8 4 2506 09 h...
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 73 00 d8 00 6e 00 ec 00 88 b8 75 30 85 34 7b 0c s...n... ..u0.4{.
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00e0: 29 00 80 1c 00 00 00 00 00 00 00 00 00 00 00 00 )....... ........
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
And without auto-negotiation I have link but no IP by DHCP. If I put the IP manually It doesn't have connection:
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
10M-baseT-full
100M-baseT-half
100M-baseT-full
1G-baseT-half
1G-baseT-full
1G-baseX
2.5G-baseT
2.5G-baseX
5G-baseT
10G-baseT
10G-baseSR-LR
10G-baseCR
10G-baseSR-LR
sfp-rx-loss: no
sfp-tx-fault: no
sfp-supply-voltage: 3.278V
00e0: 29 00 80 0c 00 00 00 00 00 00 00 00 00 00 00 00 )....... ........
I tried forced speed with 1G-baseT-full but the problem persist. What am I doing wrong?
Thanks for all, kind regards.
SM5310-T SFP+ is a 10Gbit module. So you should set it to 10Gbit, not 1Gbit.
Thanks for response but when I forced the speed to 10G-BaseT, 10G-BaseSR-LR or 10G-BaseCR there isn't link in the interface.
The CCR is connected to a unmanaged gigabit switch.
I tried with another module and Its working. I force speed to 1G and the DHCP client get IP of the network.
You cannot blindly assume that a 10Gbit module can be set to 1Gbit and then make connection to a 1Gbit module at the other end. Some can do that, but others (probably most) cannot.
I think you misunderstood. I'm use the SFP+ port of the CCR with the TP-Link SFP+ transceiver to connect with a ethernet cable to unmanaged gigabit switch, not a SFP module.
It's work fine with other module, same model. I have link and DHCP client get IP of the network.
Kind regards.
