Problem with Chateau Pro AX
I’m having a problem with the new Chateau Pro AX, specifically with the 2.4GHz interface. After several days of troubleshooting, I eventually went back to basics and, abandoning Capsman, manually configured the following network on the 2.4GHz interface:
set [ find default-name=wifi2 ] channel.width=20mhz configuration.antenna-gain=5 .country=Poland .manager=local .mode=ap .ssid=IoT datapath.vlan-id=440 disabled=no mtu=1500 security.authentication-types=wpa2-psk .encryption=ccmp
According to Mikrotik, the interface is working – tx-power is set to 15, and clients are connecting to it. However, the problem is that they keep disconnecting frequently, usually with the following message:
28:37:2F:8B:60:88@wifi2(IoT) disconnected, not responding, signal strength -48
That would be understandable if the client had a weak wireless adapter. But the same client maintains a stable connection with other access points, both with the old wireless setup and the new hAP AX (there are several APs in the house due to its layout). Additionally, in NetSpot, the Wi-Fi network appears briefly and then disappears.
I’ve tried connecting various devices – same result, as if the network is vanishing intermittently (even though the Chateau Pro AX doesn’t report any issues).
Do you have any idea what is going on? Just to be clear – this is the exact same configuration that’s being distributed by CAPsMAN to the other access points (two NetMetals AX/AC outside the house, a hAP ax on the ground floor, and a hAP ac on the upper floor) – and everything works fine everywhere else. The issue occurs only here.
http://forum.mikrotik.com/t/not-responding-f-k-a-sa-query-timeout/168864/1
Try the nightly on the AP:
https://mt.lv/nightly-build
Caution, this is pre-release that most likely contains other bugs. I can’t guarantee that with this version something will not burst into flames or something. > https://mt.lv/nightly-build > DO NOT INSTALL THIS if you use it for something important.
I am still testing with ccmp/wpa2/wpa3 FT steering and connection-priority=0/1
My findings so far.
Old stuff does the headless chicken dance.
In other words, this sequence was an older 2.4g only phone arriving then stomping between the 2 choices it has.
2.4g upstairs Cap-2 or wifi2 2.4g downstairs. I had to add it to the Cap-2 reject list!
I am not 100% sure how a wifi call would survive that.
2025-06-09 15:27:00 wireless,info 1C:@cap-(001) connected, signal strength -49
2025-06-09 15:47:09 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -59
2025-06-09 15:47:57 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -51
2025-06-09 15:48:07 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -56
2025-06-09 15:51:41 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -45
2025-06-09 15:51:56 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -49
2025-06-09 15:52:33 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -48
2025-06-09 15:53:03 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -68
2025-06-09 15:53:43 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -50
2025-06-09 15:56:17 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -54
2025-06-09 15:56:24 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -53
2025-06-09 15:57:57 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -51
2025-06-09 16:15:23 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -35
2025-06-09 16:15:40 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -47
2025-06-09 16:16:07 wireless,info 1C:@wifi2(001) roamed to 1C:@cap-2(001), signal strength -57
2025-06-09 16:16:19 wireless,info 1C:@cap-2(001) roamed to 1C:@wifi2(001), signal strength -65
Well behaved AC device 2.4g/5g Which shows the FT flag
In this sequence the device arrives connecting to the 2.4g then moving to the 5g, 20 mins later same again
after going out to collect food from the deliveroo driver.
2025-06-09 16:57:43 wireless,info @cap-2(001) roamed to 9E:@cap-1(001), signal strength -50
2025-06-09 18:21:02 wireless,info 9E:@cap-1(001) roamed to 9E:@cap-2(001), signal strength -59
2025-06-09 18:21:07 wireless,info 9E:@cap-2(001) roamed to 9E:@cap-1(001), signal strength -64
2025-06-09 18:23:25 wireless,info 9E:@cap-1(001) disconnected, connection lost, signal strength -88
2025-06-09 18:24:52 wireless,info 9E:@cap-2(001) connected, signal strength -48
2025-06-09 18:24:55 wireless,info 9E:@cap-2(001) roamed to 9E:@cap-1(001), signal strength -53
This has a choice of 2x 2.4g and 1x 5g
In this sequence AX device leaves the building from Cap-1 5g then rejoins back back on Cap1 5g
2025-06-09 14:45:17 wireless,info AE:@cap-wifi1(001) disconnected, connection lost, signal strength -87
2025-06-09 15:03:31 wireless,info AE:@cap-1(001) connected, signal strength -71
This Also has a choice of 2x 2.4g and 1x 5g
2025-06-09 17:29:47 by RouterOS 7.21_ab105
software id =
model = C52iG-5HaxD2HaxD
serial number =
/interface wifi channel
add band=5ghz-ax comment=25mw disabled=no frequency=5745 name=155 skip-dfs-channels=10min-cac width=\20/40/80mhz
add band=5ghz-ax disabled=no frequency=5180 name=42 skip-dfs-channels=10min-cac width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5500 name=106 skip-dfs-channels=10min-cac width=20/40/80mhz
add band=2ghz-ax disabled=no frequency=2412 name=1 skip-dfs-channels=10min-cac width=20mhz
add band=2ghz-ax disabled=no frequency=2437 name=6 skip-dfs-channels=10min-cac width=20mhz
add band=2ghz-ax disabled=no frequency=2462 name=11 skip-dfs-channels=10min-cac width=20mhz
/interface wifi
set [ find default-name=wifi1 ] channel=42 configuration.country=“United Kingdom” .mode=ap .ssid=002
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp .management-protection=
allowed .wps=disable
add configuration.hide-ssid=yes .mode=ap .ssid=Radio disabled=no mac-address=1A:
master-interface=wifi1 name=wifi3 security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp .wps=\disable
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk connect-priority=0/1 disabled=no encryption=ccmp ft=yes
ft-over-ds=yes management-protection=allowed name=sec1 wps=disable
/interface wifi steering
add disabled=no name=steering1 neighbor-group=dynamic-001-db6d2cec rrm=yes wnm=yes
/interface wifi
operated by CAP 48:%bridge, traffic processing on CAP
add channel=106 channel.frequency=5500 configuration.country=“United Kingdom” .mode=ap .ssid=001
disabled=no name=cap-1 radio-mac=48: security=sec1 steering=steering1
add channel=1 configuration.country=“United Kingdom” .mode=ap .ssid=001 disabled=no name=cap-2
set [ find default-name=wifi2 ] channel=11 channel.frequency=2462 configuration.country=“United Kingdom”
.mode=ap .ssid=001 disabled=no security=sec1 steering=steering1
/interface wifi access-list
add action=reject disabled=no interface=cap-2 mac-address=1C:
/interface wifi capsman
set enabled=yes
Hi itimo01, is there any problem with downloading nightly for windows 11? Are there any data conflicts?
