Hello
I have a modem and ppoe connection set in modem .
Now I connect modem to mikrotik 951 via ethernet and now mikrotik access to internet
I want to access my mikrotik in out.
But Cloud send error “see pic” and when enter to DNS name I connect to modem instead connect to Mikrotik
EVEN I write port forward in modem “see pic” but it doesn’t work
Please help
Warning in RouterOS says that local address is 192.168.2.2. Your port forwarding rule uses 192.168.0.1. That does not look like something that has any chance to work.
First I have set 192.168.0.1 and test
Second after I see this warning change portf orwarding to 192.168.2.2
in both mode did not work
Why do not put your modem in bridge mode and activatte pppoe client on your mikrotik? Or use DMZ?
In some reason I couldnot change modem to bridge mode but I config DMZ in modem and I set Mikrotik IP in modem’s DMZ but I could not connect to mikrotik , instead I connect to modem
So, if you set DMZ, you do not need a NAT rule, but a Firewall rule in INPUT chain for Winbox.
After your replay I delete nat and create input rule in firewall but when I enter modem’s public IP I connect to modem instead mikrotik
Wich port are you trying to reach?
8921 for winbox
and 80 for webfig
There is no body can solve my problem?
Be sure how the dmz setting works in your modem. Put accepting rule for the tcp port you want to reach in input chain high enough to get the packet to the router.
after your post I created this rule but yet I enter the cloud address I connect to modem instead connect to mikrotik
If anyone wants I could remote access via team viewer
