On Unifi I have set 3 wifi network with 3 VLAN, on mikrotik I have bridge with 4 VLAN (3 for wifi, 4 for Unifi Device), and when I connect to wifi with my device, then I don’t have IP from DHCP-server. When I run this via ether cable then DHCP work great.
What I must have to working DHCP-SERVER from Unifi WiFi?
On sniffer and tcpdump on Unifi I see ARP who-has packets, and response, but not IP, when I settings static IP then I can’t ping mikrotik from wifi devices, but on sniffer I see ICMP Request…
Can you confirm your unifi AP wants by default to accept the mangement vlan untagged into the router and all the data vlans as tagged (over the port leading from MT)??
Will depend, its either a trunk port to the UNIFI carrying all vlans and the management vlan ( the one that the UNIFI should get its IP address from ) could be one of the existing vlans if its considered TRUSTED, or, it would need to be a hybrid port.
