I have a problem with the configuration of the router .
On the provider’s network settings to get DHCP. Configuration below hosts ping
Internet comes to the router,but the pages,sites do not open, maybe not the right set up NAT, DNS, Route? Firewall disabled on time , it is permissible? I understand that I do not possess the fundamental knowledge in networking,but I try to get them,learn wiki, wiki mikrotik and networking technologies.
Thank you all for your help!
Configuration:
[admin@MikroTik] > export
# jan/02/1970 01:16:31 by RouterOS 6.20
# software id = RCET-6MMR
/interface wireless
set [ find default-name=wlan1 ] disabled=no l2mtu=2290 mode=ap-bridge \
radio-name=KOSTYAHOME2 wireless-protocol=unspecified
set [ find default-name=ether1 ] mac-address=00:1D:60:D6:EC:6F
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=sfp1 ] speed=100Mbps
/ip neighbor discovery
set wlan1 discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys wpa-pre-shared-key=123456789 wpa2-pre-shared-key=123456789
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=pool1 ranges=192.168.89.2-192.168.89.30
add name=pool2 ranges=192.168.89.34-192.168.89.62
add address-pool=pool1 disabled=no interface=ether2 lease-time=3d name=\
server1
add address-pool=pool2 disabled=no interface=wlan1 lease-time=3d name=server2
/port
set 0 name=serial0
/routing bgp instance
set default router-id=192.168.160.254
/system logging action
set 0 memory-lines=100
set 1 disk-file-name=log disk-lines-per-file=100
set 2 remember=yes
set 3 src-address=0.0.0.0
add address=192.168.89.1/24 interface=ether2 network=192.168.89.0
add address=192.168.89.33/24 interface=ether2 network=192.168.89.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether1
add address=192.168.89.0/27 dns-server=192.168.0.107,192.168.0.108 gateway=\
192.168.89.1
add address=192.168.89.32/27 dns-server=192.168.0.107,192.168.0.108 gateway=\
192.168.89.33
set allow-remote-requests=yes servers=192.168.0.107,192.168.0.108
/ip dns static
add address=192.168.0.107 disabled=yes name=base
add address=192.168.0.108 disabled=yes name=base2
add action=masquerade chain=srcnat src-address=192.168.89.0/24
/ip ipsec policy
set (unknown) dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set cache-path=web-proxy1
add disabled=yes distance=1 gateway=192.168.160.254
/ip service
set api disabled=yes
/ip upnp
set allow-disable-external-interface=no
/snmp
set trap-community=public
Once again I apologize for the mistakes!
Thank you!
P.S. Sorry I tried to open the topic in another section,I will try to be attentive to the rules.
Connect never ISP modem to a gigabit interface.
For a good performance take for example ether6 100 Mbit interface
your iSP have not a speed from more than 100 Mbit.
Reset your routerboard without default configuration.
Connect your ISP to ether6
Copy and paste this configuration in “new terminal”
add mtu=1500 name=bridge-lan
set [ find default-name=ether1 ] name=ether1-LAN
set [ find default-name=ether2 ] master-port=ether1-LAN name=ether2-LAN
set [ find default-name=ether3 ] master-port=ether1-LAN name=ether3-LAN
set [ find default-name=ether4 ] master-port=ether1-LAN name=ether4-LAN
set [ find default-name=ether5 ] master-port=ether1-LAN name=ether5-LAN
set [ find default-name=ether6 ] name=ether6-ISP
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=belgium disabled=no l2mtu=2290 mode=ap-bridge
add name=dhcp_pool-LAN ranges=192.168.89.2-192.168.89.254
add name=dhcp_pool-WLAN1 ranges=192.168.90.2-192.168.90.254
add address-pool=dhcp_pool-LAN disabled=no interface=bridge-lan lease-time=3d name=dhcp-LAN
add address-pool=dhcp_pool-WLAN1 disabled=no interface=wlan1 lease-time=3d name=dhcp-WLAN1
/port
set 0 name=serial0
set 2 remember=yes
add bridge=bridge-lan interface=ether1-LAN
add address=192.168.89.1/24 interface=bridge-lan network=192.168.89.0
add address=192.168.90.1/24 interface=wlan1 network=192.168.90.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether6-ISP
add address=192.168.89.0/24 dns-server=192.168.89.1,8.8.8.8,8.8.4.4 gateway=192.168.89.1
add address=192.168.90.0/24 dns-server=192.168.89.1,8.8.8.8,8.8.4.4 gateway=192.168.90.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.89.1 name=router.home ttl=1w3d
add action=masquerade chain=srcnat comment=masquerade-LAN out-interface=ether6-ISP src-address=192.168.89.0/24
add action=masquerade chain=srcnat comment=masquerade-WLAN1 out-interface=ether6-ISP src-address=192.168.90.0/24
/ip upnp
/snmp
Hello!
Thank you all for your attention and thank you very much plisken
Hello, why 2 ranges on 1 /24 range?
Have you problems with
LAN= 192.168.98.1/24
WLAN1= 192.168.90.1/24
So, is it wrong? I should start from 2/24 range?
to plisken
I tried to do as you indicated
But, unfortunately, the Internet, and does not work, but has now changed as follows . On port ether2 - internet access is, in no other ports (connection is limited or non-existent )
Here is the final configuration after making your changes:
# jan/02/1970 01:57:30 by RouterOS 6.20
add mtu=1500 name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=belgium disabled=no \
l2mtu=2290 mode=ap-bridge radio-name=KOSTIKHOME2 wireless-protocol=\
unspecified
set [ find default-name=ether1 ] mac-address=00:1D:60:D6:EC:6F name=ether1-LAN
/ip ipsec proposal
add address-pool=pool1 disabled=no interface=ether2 lease-time=3d name=server1
add address-pool=dhcp_pool-LAN disabled=no interface=bridge-lan lease-time=3d \
name=dhcp-LAN
/port
set 0 name=serial0
set 2 remember=yes
add bridge=bridge1 interface=ether1-LAN
/ip dhcp-client
192.168.89.1
add address=192.168.89.0/24 dns-server=192.168.89.1,8.8.8.8,8.8.4.4 gateway=\
192.168.89.1
192.168.89.33
add address=192.168.90.0/24 dns-server=192.168.89.1,8.8.8.8,8.8.4.4 gateway=\
192.168.90.1
/ip dns static
add action=masquerade chain=srcnat comment=masquerade-LAN out-interface=\
add action=masquerade chain=srcnat comment=masquerade-WLAN1 out-interface=\
# in/out-interface matcher not possible when interface (ether1-LAN) is slave - use
master instead (bridge1)
add action=masquerade chain=srcnat out-interface=ether1-LAN
add action=masquerade chain=srcnat out-interface=bridge1 src-address=\
192.168.89.0/24
/ip ipsec policy
/ip proxy
/ip service
/ip upnp
/snmp
[admin@MikroTik] >
Have you before reset the routerboard without default configuration?
Have you connect the internet on ether6?
What IP-adress have you on the DHCP-client (ether6)
I have internet to my test setup
I have 192.168.160.12 IP-adress on the DHCP-client.
May be I don’t reset the routerboard without default configuration.
I changed MAC adress on this port (ether6) and take link on this port, but I try to check internet from this port - it’s no internet.
Ok I will try it again and check it. Thank you. And sorry.
I have internet configured (DHCP-client) on ether6 (100 Mbit) WAN
If on DHCP client (ether6) bound are you connected to the internet.
You should then be able to ping to 8.8.8.8
ether1 to 5 is the LAN site
Don’t forget before you copy and paste the configuration a made you must reset your routerboard without default configuration
This is verry importent
I try to “copy-past”. And I have next problem. I don’t to do all “copy-past”, so but use parts of code, because exist some error. Ok, more code successful “enable”. But exist next problem. - Like port ehert6 after to change MAC-address have no connection to Internet, but link exist and exist transfer packages. My be it will be need to creation VLAN? So Ports ether1-eher2 exist Swich1 and Ports ether6-ether10 exist Swich2. I don’t know may be I wrong? And all works without VLAN.
So it’s your configuration, after reset the routerboard without default configuration and part of “copy-past” Code and part manually typing:
[admin@MikroTik] >> export
# jan/02/1970 00:40:26 by RouterOS 6.20
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g l2mtu=2290
[b]set [ find default-name=ether6 ] mac-address=00:1D:60:D6:EC:6F[/b]
name=dhcp-LAN
add address-pool=dhcp_pool-WLAN1 disabled=no interface=wlan1 lease-time=3d \
name=dhcp-WLAN1
/port
set 0 name=serial0
set 2 remember=yes
/ip dns static
/ip upnp
/snmp
[admin@MikroTik] >>
And in attache some Code with information message with “…don’t much any value of interface…”
I called today to my ISP to take some more information about my configuration but ISP couldn’t to give me more information, I try to call again tomorrow.
Thank you very much again!
P.S. When I change my MAC-address of eher6 it have name change like this - set [ find default-name=ether6 ] mac-address=00:1D:60:D6:EC:6F
Is it normal?
I called to ISP and they to give me all configuration, but not have another information, but said, that another people, which have equipment like Mikrotik have Internet, connection correct.
Screenshot DHCP-client status
I see no gateway this is wrong this must the IP-adress from the ISP modem.
I think
There is something wrong with the DHCP server lease by your provider.
At “standard gateway” should be the IP address of the ISP modem
Sorry but i have internet on my test setup this is verry weirde
Hello, no I have no Internet on LAN (ether1,2,3,4,5)
Ok, I send you screenshot, but late
And today I am happy, I receave Configuration from ISP. And ISP change my diapason of LAN and they said before I have bridge with one port. I don’t know right it?
And for a first configuration change ether6 to ehter1. I try to change it after when all working right and to connection to Internet.
Yes you have 1 interface in bridge because you can build further with LANyou can put ether 7,8,9,10 in this bridge.
Thats not a problem.
The ISP set gateway on a gigabit port (ether1) why? i don’t now. The performance from the first switch chip is not fully used with that.
I hope for you that it works.
If you have problems or if it works let me know.
Ok, Thank you! I will check it. I don’t know why ISP set gateway on a gigabit port (ether1) I try to change it in further. At first I think try it will be work with just it, after it can configuration.
