I am new to the forum and new to MikroTik, please let me know when I post something that is against forum rules and I will adjust my post.
I have purchased a RouterBOARD hap ac lite to use as a CPE with the wireless ISP at my home.
The first attempt to get this working all was fine, worked like a charm.
In the Quickset screen I selected CPE, connected the 2.4GHz radio to the ISP and I created an inside SSID on the 5GHz radio.
This was a very nice first experience with MikroTik/RouterOS.
That is, until I updated RouterOS…
The version of RouterOS that came with my router is 6.30.x, I upgraded to 6.35.x.
After the upgrade the CPE mode doesn’t work like it did before.
My settings were gone after the upgrade and when I try to setup CPE mode the RouterBOARD wants to connect to the 2.4GHz ISP signal by using the 5GHz radio and it disabled the 2.4GHz radio.
When I manually assign the 2.4GHz radio to the ISP by putting it in “station” mode and connecting it to the ISP signal I do not get an IP address.
I have tried numerous resets to factory default but it seems that only takes the RouterBOARD out of CPE mode and as soon as I set it back to CPE mode the broken settings are back and I cannot connect to the RouterBOARD anymore.
As a RouterOS/MikroTik newbie I am now kinda stuck and decided to ask for help on the forum.
I hope you can help me or give me some good pointers, any help is much appreciated!
With kind regards,
Marcel
