Problem with data rate on 5.3GHz link
Hi, just looking for some understanding of why this might be happening. We a PtP link between two sites. Signal strength on both sides is around -59 give or take a little. Frequency is in the 5.3Ghz range. Pings between both sides are around 5ms and for all intents and purposes the spectrum is clear.
What is happening is that the AP data rate locks down around 54Mbps, but the SU data rate will jump to 54Mbps and then go back to 6Mbps. I’ve reduced the supported rates as low as 12Mbps to see if the SU would lock down there to no effect. The SU just never seems to get a data rate above 6Mbps while the AP is doing fine.
We do have nstreme turned on, but otherwise the link has no special settings.
Anybody have any idea why this would be happening?
Thanks in advance
Why is it a problem? Does your link slowing down? Try to leave rate at 54 (or try 48,36), and ping on empty state, 5mbps btw test (tcp, one way), 10mbps, and 15mbps (or even 20mbps). If ping does not grow over 10ms, your link can stand that speed perfekt.
We have some 5,3GHz link, and see what you’re talking about, but causes no problem.
hey mip
i am having this issue link is -59 -63 nstream but my issue is ping rates very alot from 5ms to 60ms from ap to station. have asked before no one responds.
any suggestions
Randy
Well, it’s a problem because we’ll be backhauling 3 T1’s for a cell phone company over the link. It has to be perfect by a standard that normal IP radio’s for ISP’s don’t have to adhere to. It just makes me uncomfortable to see that both sides aren’t balancing at the same data rate.
I just wonder if this is a bug with the mikrotik software, or a problem with setup. I truthfully have no clue. Tomorrow I’ll be going out to the towers to run additional tests, so maybe I’ll have more information again. But any help/hints would be greatly appreciated.
Hmm,
Backhauling T1’s using WiFi technology isn’t generally recommended
Every time the radio “rate adjusts” you will lose some traffic I think.
For cell companies, there is zero tolerance for lost data, as the voice traffic itself is compressed - so the consequences for the user are even worse!
We tested “TDM-over-IP radio” and never got it to work without errors, even in the lab, short range, no interference.
That being said, I remember a post from another user who’d used different TDMoIP boxes and got 2 out of 3 links working.
Would be impressed if this solution can be made to work, anyone else got E1’s or T1’s over radio working?
I would be kicked off the forum for advocating laser for E1 or T1 backhaul, so I won’t :unamused: and though that works great, of course they are restricted in distance.
We do have customers who want E1’s over radio, but for now, no solution - unless someone has one working - please post-
Regards
These are all wild guesses, but i needed a break from what i was doing :slight_smile:
Try setting the basic rate up to say 12 mbits on each side and stop using 6 mbit alltogheter in the rates. Does it stick at 12mbits?
Just a wild guess but could be that one side sends almost exclusivly broadcast/multicast packets and thus sticks at basic rate.
One thing you could try is to ping the remote end with intensity to see if that changes anything.
Also i’ve seen this behaviour when the radios/antennas generate alot of noise due to bad hardware. I dont think there is any place that indicates noise on the radio itself. It could be some kind of feedback into the radio. I mean, the radio kind of generates it’s own noise when transmitting.
sten
ping 192.68.10.11 -t -l 1500 does increase a little from 17ms - 100ms
i am going to change or lock down the freq and thruput see if it changes.
Randy
