Problem with DNS
I have a route network. The gateway to the Internet is 10.10.11.1. All directly connected subnets have through a source nat access to the internet. Now I have an subnet 10.10.13.0/24 which is firstly through a mikrotik router connected to 10.10.12.0/24 trough srcnat and the ip 10.10.12.100 and 10.10.12.0/24 is connected to the gateway. I can ping out of this subnet to ip’s in the internet, but I can not get a html side displayed. It is very likely an DNS-resolution problem. SO please I hope someone can say me how I should configure DNS to work in the subnet and to make it possible to view web pages!
with best regards
hkaiser
i think you should set the same dns as the gateway’s
i think you should add static dns entry with your router ip and some name
