Hy all.
My setup is:
I setted up a transparent proxy on ROS 3.0rc13 on x86:
[admin@xxxx] > /ip proxy print
enabled: yes
src-address: 0.0.0.0
port: 8000
parent-proxy: 192.168.0.89
parent-proxy-port: 3128
cache-drive: system
cache-administrator: "xxx@yyy.it"
max-cache-size: none
cache-on-disk: no
max-client-connections: 1000
max-server-connections: 1000
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
and then i set a redirect:
/ip firewall nat print
2 ;;; Proxy Redirect
chain=dstnat action=redirect to-ports=8000 src-address=192.168.0.91
dst-address=!192.168.0.89 dst-port=80 protocol=tcp
The only thing i obtain, is a “cache-denied” from squid.
I use radius to auth my user with squid, and if i set it directly on the client’s browser, it work perfectly (popup request with user and pass to client on first attempt to access to Internet).
It seems that RoS tryes to access my squid without auth. How can i force it?
I tryied to set a dst-nat/dst-nat, but it, obviously, won’t work. It seems that i need for transparent proxy (but with auth).
How can i do?
