I tried to create failover to backup ISP, i followed a few Youtube videos where everything is explained but I stuck… I can’t get it to switch over to another ISP.
If I disconnect the cable from primary ISP it’s working, but if I simulate network outage by disconnecting WAN from the ISP router but router itself stays up I get the first route (marked as ISP1) as unreachable after 20 seconds but it doesn’t switch over to another route. I tried watched different videos but nothing worked…
Here is my test setup:
# 2024-11-05 06:31:28 by RouterOS 7.17beta2
# software id =
# model = C52iG-5HaxD2HaxD
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik- \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
.ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik- \
.ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=backup interface=ether2 list=WAN
192.168.88.0
/ip dhcp-client
add add-default-route=no comment=defconf interface=ether1
add add-default-route=no comment=backup interface=ether2
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.188.1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.100.100 \
add check-gateway=ping comment="Monitor ISP1" disabled=no distance=1 \
dst-address=8.8.8.8/32 gateway=192.168.100.100 routing-table=main scope=\
10 suppress-hw-offload=no target-scope=10
add comment="Monitor ISP2" disabled=no distance=1 dst-address=1.1.1.1/32 \
gateway=192.168.188.1 routing-table=main scope=10 suppress-hw-offload=no \
target-scope=10
add check-gateway=ping comment=ISP1 disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=10 \
suppress-hw-offload=no target-scope=11
add comment=ISP2 disabled=no distance=2 dst-address=0.0.0.0/0 gateway=1.1.1.1 \
routing-table=main scope=10 suppress-hw-offload=no target-scope=11
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Zagreb
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
This is pure default configuration.
