Hello!
I’m having a bit of a trouble configuring a WAN failover in Mikrotik. I’ve done it a lot of times with no problems, but this time is different.
WAN 1 is 1G fiber.
WAN 2 is LTE.
Problem is that the ISP router in WAN 1 replies ping with net unreachable (this is the difference VS the other times I’ve done this, normally the ISP router simply doesn’t reply when there’s no internet connection), so the route detects the reply and keeps the route active even when is not the host (1.1.1.1) who is responding but the router.
What can I do?
(Sorry for my English)
This is the config. Firewall & LAN config not included because not needed for this.
Problem here is that ISP1 router replyes with “net unreachable (when there’s no connection)” when you make ping to any host outside the ISP router’s LAN. Mikrotik detects the host (1.1.1.1 in this case) like up and reachable because it’s receiving an ICMP reply. Earlier firmwares of this same ISP router do not reply when there’s no connection, so the route checking works and detects this connection like down.
I’m sorry if I’m not explaining very well. English is not my best.
It is expected that the ISP router replies to a PING (ICMP). The content of the reply could be “unreachable”. The Mikrotik understands this answer, and flags the tested host as down (the pinged host as unreachable).
This is not what we want to test with a check-gateway. The check-gateway checks the gateway, not the destination.
The check-gateway s should (also) be on the gateways 1.1.1.1 and 9.9.9.9 , and that’s missing in your initial config. You only check the local gateways 192.168.1.1 and 192.168.2.1. This will not see any problems behind those local gateways!
@raphaps config is better. It checks gateways 1.1.1.1 and 9.9.9.9. The local router check is not so important, we stop using those local routers when 1.1.1.1 or 9.9.9.9 is not responding.
When you say there is no connection, are you referring to ISP1 being down or you unplugging the cable? For me, the operation in both version 6 and version 7 of RouterOS is the same; I tested it here and it appears to be the same. If your ISP1 is down in the sense of unplugging the cable from the interface, removing the address from the interface, or the ISP1 modem shutting off, 1.1.1.1 will still be reachable through the next configured route. This would happen even if you weren’t using recursive routing. In the case where everything is connected, but there is no internet on ISP1, then indeed 1.1.1.1 will be unreachable. Remember that the main function of recursive routing is this: the route checks for a next hop that is not directly connected to the local router.
What @bpwl mentioned is also important. You are performing the check-gateway ping in the wrong place; it is being done for the addresses 1.1.1.1 and 9.9.9.9 when it should be done in the default route settings.
If you want to perform a test, you can block the address 1.1.1.1 and see if the WAN2 route becomes the primary one.
