Problem with first RB450G
i’ve tried to configure my first RB450G as firewall.
I’ve set
LAN 192.168.88.1
WAN 91.81.145.142
My ISP router/gateway have IP address 91.81.145.141
It doesn’t work!!!
I followed the wiki step by step but there’s no way.
If i try to ping ISP gateway i have no answer;
I’ve configured my laptop with the same wan ip and gateway address: it works properly
Can anybody help?
Raffaele
What netmask did you set ?
On the MikroTik you need to specify 91.81.145.142/XX in the wan address.
You will also need to add a default route via the 91.81.145.141
Nick.
Can not miss:
IP → DNS
Select Allow Remote request
IP - Firewall - NAT - ADD → Action Mascared
